jackplate on a 24? >
jackplate on a 24?
jackplate on a 24?
Old 08-13-2005 | 10:27 AM
Default jackplate on a 24?
i have a 24 with a 225 pro max and wondering if i should go with a jack plate?
joneill is offline
Old 08-13-2005 | 10:38 AM
SUPERSTITIOUS's Avatar
Default Re: jackplate on a 24?
I believe the jackplate is a must if your looking for top end as well as a setback if at least 12"
SUPERSTITIOUS is offline
Old 08-13-2005 | 09:07 PM
rchevelle71's Avatar
You mean your motor is mounted on the Transom???
if so then Hell Yeah!!! Just ordered the 10" for the Pantera(similar hull), 6" wasnt enough, motor hit the transom when tilted.
rchevelle71 is offline
Old 08-14-2005 | 02:09 PM
yes it is on the transom, what is the better brand to go with?
joneill is offline
Old 08-14-2005 | 03:17 PM
Id do a 12in. setback then add the electric jackplate behind it to pick up an additiional 3-4 in. Good to go in many conditions. Oh yeah Id do transome bracing as well.
Old 08-14-2005 | 04:21 PM
thayes11's Avatar
IUOE L94
My uncle has a 24' i/o converted it to an o/b with a 12' Setback. Worked out real nice with a 250 EFI, did not ride as good with the o/b but went few mph faster and was more reliable.
thayes11 is offline
Old 08-15-2005 | 04:42 AM
what mph should i hope to pick up by going with the jack plate, or setback?
joneill is offline
Old 08-15-2005 | 05:31 AM
FX10's Avatar
If I'm not mistaken, Superbash has a 18" on his 2003 24' Superboat. The boat rides and handles sweet.
FX10 is offline
Old 08-15-2005 | 05:33 AM
FX10's Avatar
Also if setting back the motor. Remember that all that torque on the transom is multiplyed. A tie bar system need to be put in.
FX10 is offline
Old 08-15-2005 | 05:32 PM
are you guys running 20 or 15" mids? i have a 20"
joneill is offline
