Merc Bravo SS Props turned gray? Help! >
Old 08-14-2005 | 04:47 PM
goldenruhl's Avatar
Default Merc Bravo SS Props turned gray? Help!
I have a 2002 292 Formula and I was at one of the Finger Lakes ( Seneca Lake ) last week. The boat was in the water 24/7 for the week ( first time ). Got home and saw the props and freaked. No shine what-so-ever. They now look like a brushed stainless to a gray? They do not feel the same. When I rub them my fingers want to grab instead of slide. I've asked everyone in my boating group and no one can figure it out? Anyone ever had this or have any ideas. The mer-cathodes are working fine. Any suggestions on cleaning. I am really fussy and don't want to make a mistake on cleaning. I got to get these back to the shinny stainless! Any help will be greatly appreciated!
Thanks in advance,
Rick
goldenruhl is offline
Old 08-14-2005 | 04:58 PM
The Menace's Avatar
Default Re: Merc Bravo SS Props turned gray? Help!
Have you tried washing with some LimeAway? Probably some type of mineral common in your water.
The Menace is offline
Old 08-14-2005 | 05:45 PM
Outdrive1's Avatar
Masher touches my
Try lime away or a non abrasive toilet bowl cleaner. Non-abrasive being the key, don't use a Scotch pad or steel wool, you'll ruin the finish.
Outdrive1 is offline
Old 08-14-2005 | 07:21 PM
formula31's Avatar
Muriatic acid. Hold your nose. Dont do it over your concrete.
formula31 is offline
Old 08-14-2005 | 11:35 PM
goldenruhl's Avatar
Thanks for the advice. I can't thank you enough!
Happy boating,
Rick
Old 08-15-2005 | 06:26 AM
GOODT's Avatar
if all else fails use rubbing compound on a rag works well!
GOODT is offline
Old 08-15-2005 | 12:55 PM
SeaRay Jim's Avatar
Lime-away, Zepp Lime and Calcium remover, NE outdrive cleaner, CLR etc. I used CLR on mine about a month ago (after getting that crap like you did) and it worked ok, but I think Zepp (in gallons from Home Depot) worked better. Muratic Acid should do it too, but it's probably the trickiest to work with.
SeaRay Jim is offline
Old 08-16-2005 | 01:02 AM
goldenruhl's Avatar
Thanks so much for all the help guys!
Rick
Old 08-16-2005 | 08:30 AM
BajaRunner's Avatar
I just did that to a spare set. Acidic Toliet Bowl Cleaner from home depot. they look new.
BajaRunner is offline
innovator1
Swap Shop
0
09-14-2008 08:34 AM
cdscarab
Prop Talk
3
07-19-2005 10:00 PM
WildWarrior
Cigarette
18
07-18-2005 06:51 AM
JoeD
06-08-2005 08:39 PM
HOTTZU98
3
05-13-2005 07:43 AM
