Tranny Trouble 454 Mag, Bravo :( >
Old 08-14-2005 | 05:43 PM
Default Tranny Trouble 454 Mag, Bravo :(
sunny day, boating shift from neutral, nothing happens, no noise, shift cable fine, working at motor, do I have to drop drive now to check? anyone know what the cable going to the drive attaches to in the drive? thanks in advance!!
RYAN
2000 H2X BOSS 454 MAG MPI
H2X BOSS is offline
Old 08-14-2005 | 06:15 PM
Pwrbt33's Avatar
Talking Re: Tranny Trouble 454 Mag, Bravo :(
Do you have reverse? If you have nothing thats not good. As you already know, start the engine and look over the back of the motor and see if the input shaft is spinning with the coupler on the engine. If it is, its time to pull the drive. The lower shift cable attaches to a shift arm which is attached to another shaft with the shift fork. Do you have any resistance when shifting? You may have broken a shaft if everything else checks out.
Good luck!
John S.
Pwrbt33 is offline
Old 08-14-2005 | 06:27 PM
OldSchool's Avatar
Default Re: Tranny Trouble 454 Mag, Bravo :(
....and if the shaft isn't spinning, it's coupler time!!
OldSchool is offline
Old 08-14-2005 | 06:41 PM
Pwrbt33's Avatar
I just love it when he helps out !!
Thanks Craig !!!
Hows the BIG DOG running?
John S.
Pwrbt33 is offline
Donzi502
Prop Talk
0
10-07-2006 03:00 AM
DURANGOKID59
17
08-14-2006 08:05 AM
jackhammer
7
06-09-2004 08:28 AM
Pascagoula Run
0
11-16-2003 02:46 PM
Love Machine
2
09-09-2003 05:03 PM
