496 CNC ed heads by Tyler Crocket
What a nice piece ,flow sheets show 28.5 % increase.My own measurement show 24.5% increase in exhaust ports and valves are 100 thousands larger with smaller shafts . My mehcanic was real pleased .They do make stock heads look like a toy.there being installed under my whipples as we speek on top of a monster cam and other good stuff hope to see 750 825 hp the old motors made 640 hp 7lbs boost no troubles 354 hrs old long blocks still in tact 150 compression on one 160 on the other
Got any moore info on your motor. What bore etc. I am running 750 HP on 5lbs boost bore is 30 over. I'm sure i would see at least 800hp with 7lbs boost. If you have any pics please post.
Bobby check out the Pokerruns post........their talking about you again. Under PC poker runs. Oh yeah and for all you on here don't listen to him I beat him with my 68mph boat again this year..........
The 496,s are new style 30 over cam specked by Whipple ecu done by Whipple.Mycruise speed dropped 500 rpm,s and I was at my old top end at 5/8 trottle. My8lb pulley now only makes 5lbs boost . Iwant to run 8lbs Ill know what seize I need by mon.The heads flow real good. The motors run cooler now. Ill post stats on mon.FEELfree to call 4127810881 Bob
