Won't Idle When Cold >
Old 08-18-2005 | 11:45 AM
Cmoney's Avatar
Default Won't Idle When Cold
I have twin 540's with 1050 Holley Dominator's. When cold starting, the starboard engine runs perfect but the port engine needs to be throttled for a while (until it warms up) or it will stall. It is not a big deal but was wondering if this could be adjusted, after it warms up all is good.
Cmoney is offline
Old 08-18-2005 | 11:52 AM
Default Re: Won't Idle When Cold
My twin had the same problem years ago. Turned out to be the distributer. The advance was bouncing , You could see it with a timing light. At idle one motor was steady and the other bouncing.
z.zuperboat is offline
Old 08-18-2005 | 12:01 PM
Strip Poker 388's Avatar
Rob
Maybe lean?
Strip Poker 388 is offline
Old 08-18-2005 | 12:12 PM
Cmoney's Avatar
Do you mean lean, like idle mixture?
I don't know much about the Holley's.
Cmoney is offline
Old 08-18-2005 | 12:15 PM
hillbilly24's Avatar
when you restart it do you get a plume of black smoke and soot out the exhuast or is it clear ? if it's sooty the idle mixture is too rich if not it may be too lean. check the timing and all the other basics too. and like dave said make sure the timing is holding still at idle. It may also be ideling a little low, if you have a good digitail timing light with a tach check idle speed, it realy shouldn't be done with the boats tach.
hillbilly24 is offline
Old 08-18-2005 | 12:23 PM
Cmoney's Avatar
Usually I get the black smoke cloud from both when I restart it. If I lean out the mixture screws, it wants to stall when I put it in gear or at least idles real low , even if the idle is at 850 when in neutral.
Cmoney is offline
Dave98
Powerquest
1
12-08-2006 09:29 PM
Wardey
12-31-2004 05:57 PM
baronbob
14
05-04-2004 12:29 AM
bobby daniels
01-11-2003 03:18 PM
FunHome
10-13-2002 02:53 PM
