Mods for my low performance (310 hp) 454 >
Old 08-18-2005 | 03:07 PM
Default Mods for my low performance (310 hp) 454
I just picked up this boat, http://adcache.boattraderonline.com/6/9/4/80272694.htm
and I want to mod it up some. not real sure what series the 454 is but it has low hours and is 100% stock. looking to spend like $1500.
Thanks,
Mike
Unitek is offline
Old 08-18-2005 | 03:21 PM
Default Re: Mods for my low performance (310 hp) 454
$1500 is tight budget even if you are doing it yourself. You are limited with the non-adjustable valvetrain that GM went to during these mid years. I would suggest the following:
Find a good set of OEM 049's or 781s complete for $700 to $900
Bolt on an AirGap intake $225
New Camshaft $350 to $450
This should get you 70 to 100 HP pretty easy and in that boat should push it pretty good.
Chris
cstraub is offline
Old 08-18-2005 | 03:26 PM
There is pic of the motor, can anyone tell me about it, like what generation or fuel injections on it ? also if i throw a bump stick in it will it mess with the ecm ? what about fuel and timing. it says set to 10*. I work on SBF race cars (mustangs) turning wrenches is my nature.
Unitek is offline
Old 08-18-2005 | 03:29 PM
It is a carbed (Weber) Gen 6.
cstraub is offline
Old 08-18-2005 | 03:38 PM
ok, so there is no sort of electronic control on it ? Is that setup junk or is it ok ?
Unitek is offline
Old 08-18-2005 | 07:56 PM
Pat McPherson's Avatar
I thought in 1998 the 310HP was a MPI engine, but maybe they made them both ways. The engine has L-29 100cc Vortec heads so don't advance the timing too far; stay under 30° total.
Good exhaust (Stainless Marine) really helped my 1999 7.4MPI. So that is a Great place to start. An Edelbrock RPM or RPM Airgap Intake would be a nice upgrade as well.
If you want to change the cam so she will make power past 4600rpm, you will also need a 454mag ignition module. Yours likely has a low 4650 rev limiter.
The L-29 heads stock have weak valve springs and can not take much more than .500 lift. I have a second set that were machined for new SS valves and springs for .600 lift. It cost me about $700...
If you want to tinker, be happy you have the carb version. I played with MPI calibration with a bigger cam and gain vary little with lots of $$ spent.
If I play more, the MPI is going in the scrap heep...
Patrick
Pat McPherson is offline
Old 08-19-2005 | 05:50 AM
East Coast B's Avatar
That is strange.... 98 with carb 7.4 which is 300hp at the prop.... mpi 7.4 is 310. Wonder if it's a genV motor. Thought 98 all the motors were mpi, nothing saying they didn't have some older motors sitting around when they put it together and I've seen models built a year or more before their actual haul/title date, maybe this is the case with this one.
Be careful how much power you put to those internals. Do some searching here and you'll find a LOT of info on that motor. Lot's of cast parts i.e. crank!!! The mag has the better internals. I had the 95 version of that boat with same motor, took a perfectly good motor apart and it couldn't handle the extra hp.
Good luck! It's a great boat!!!!
East Coast B is offline
Old 08-19-2005 | 09:52 AM
Great, thanks for all the helpfull tips guys ! What does the MPI intake look like ? I figured it had weak internals thats why I figured on spending $1500 or so. This is what I figure im gonna do :
Intake
cam and lifters
air cleaner / flame arrestor
MSD Box
Possibly mild port work and springs or new heads (depending on $$$ )
Will the carb that comes on that motor be ok with the mild performance this boats gonna have ? If I do a MSD will it bypass the factory rev limiter ? Not that I plan on reving it hard but would like to maybe rev to 5000 max
Unitek is offline
Old 08-19-2005 | 09:55 AM
oh and some nice roller rockers and pushrods
Unitek is offline
Old 08-19-2005 | 10:16 AM
Unitek,
SAve the money on the MSD box, for this application the stock Merc unit does just fine. The Weber will work just fine. Intakes are where the problem is. . .my E-Brock book only goes to '03 and they do not list a dual plane intake for the "peanut" port heads. A standard RPM performer will be a hell of a mismatch when bolted on. This is why I suggested finding a set of 049's or 781's; large OEM oval ports. Match a cam to the heads and with the boat having low hours the OEM lifters will work for your build.
cstraub is offline
