Vinyl Graphics R & R
Old 08-19-2005 | 11:33 AM
Default Vinyl Graphics R & R
Wanna replace just the graphics on both sides of the boat. Im gonna be taking the originals off myself and having the vinyl shop put them on. What is the best way to go about taking the graphics off ? What kind of products should I use? I have a West Marine and a few other little marine shops all around my house if someone could recomend a certain product. Here is pictures of the boat : http://adcache.boattraderonline.com/6/9/4/80272694.htm
Thanks,
Mike
Unitek is offline
Old 08-19-2005 | 11:53 AM
Wally's Avatar
Were doomed!
Default Re: Vinyl Graphics R & R
The graphics are small so you should have no problems just using a hair dryer to heat them up and just peel them off.....if any glue residue is left behind some goof off or even WD-40 will take it off.
-Wally
Wally is offline
Old 08-19-2005 | 12:39 PM
Thanks for the advise ! What is a good compound to buff the boat out with and what kind of pad should I use ? What kind of products have you had good luck with ?
Thanks,
Mike
Unitek is offline
Old 08-19-2005 | 01:42 PM
Wally's Avatar
Were doomed!
well that depends on what it looks like under the graphics. If it hasnt been exposed to the elements for too long you may just get away with hitting it with some 3M-FinessIt or just wax it. But if you have a huge difference between the two you can do a light wetsanding with some 1200 or 1500 then hit it with the 3M and wax.....
from the pics you should have minimal work...
-Wally
Wally is offline
Old 08-19-2005 | 06:00 PM
Yeah, there is little to no sun fade on the boat so it should be easy. Thanks for the help Wally !
Mike
Unitek is offline
Old 08-19-2005 | 07:32 PM
mobilecal's Avatar
Registered User
ahhh heck I liked the graphics.. But to each their own..
mobilecal is offline
Old 08-20-2005 | 02:54 PM
Im gonna re-graphic the sides. The vinyls have little tares in them and look kinda crappy up close. I like them too
Mike
Unitek is offline
Old 08-24-2005 | 01:38 AM
I wouldn't use Finness-it if you plan on re-vinyling. It leaves a film on gel thatlooks great, but doesn't let vinyl adhere properly. (use it over gel and vinyl when finished. Personally, 3M Imperial compound (white) works wonderful on gel to make it shine.The particles break down as you buff till it shines! I like the white foam compounding pads by 3m better than wool ones and aren't as messy!
Gmoney52 is offline
thehip
Detailing, Painting, & Fiberglass
13
11-04-2007 06:24 AM
boatcrazy1052
4
10-08-2007 07:14 PM
CAPTAIN CHUCK
16
07-21-2007 01:14 PM
Lt for Life
17
07-16-2006 02:25 PM
shawn
04-22-2002 07:18 PM
