This weeks Mesa Project 670 hp >
Old 08-20-2005 | 11:40 AM
Default This weeks Mesa Project 670 hp
OK I haven't posted anything lately here is a quick fix for this week this is one of our MB650na based on a 540 ci Dart block Lunati rotating assembly custom cam and ported Brodix heads I used a 9022 holley with a Dart intake for ease of use this engine made from 3000rpm to 5400rpm over 600 ft lbs of torque at 5500 rpm it made 599 ft lbs we are trying another port configuration with our standard camshaft design and were making more torque for a longer period and the engines are idling like taxi cab motors I made 16 pulls on this engine and used 6 gallons of fuel this is due to our new o2 sensor set up in each port with the stager jet set up I have in this engine we've picked up power all up and down in the RPM range . As far as I know this o2 set up is being used only by manufacturers and I can see why it's expansive as hell but it works a blind man can tune with this set up. Hope you guys enjoy. Sincerely Laz Mesa
Attached Thumbnails This weeks Mesa Project 670 hp-hpim0654.jpg   This weeks Mesa Project 670 hp-hpim0666.jpg   This weeks Mesa Project 670 hp-hpim0661.jpg
MESABALANCING is offline
Old 08-20-2005 | 11:44 AM
Default Re: This weeks Mesa Project 670 hp
The pics above include the block with the rings individually filed fit in each bore the finished short block and the finished head after cc'ing each chamber. And these are after coming out of the spray booth and on to the dyno cart for installing accessories and wiring .
Attached Thumbnails This weeks Mesa Project 670 hp-hpim0665.jpg   This weeks Mesa Project 670 hp-hpim0679.jpg
Old 08-21-2005 | 04:58 PM
Elite Marine's Avatar
Another excellent engine by Mesa. One day I'll need to get me one of those engines Laz!!
Elite Marine is offline
Old 08-22-2005 | 07:05 AM
Wow thats a sweet Pantera your getting rid I think thats one of the best boats out there .
Old 08-22-2005 | 09:35 AM
ratman's Avatar
nice numbers but whats with the pink starter? is this for a chicks boat??? sweet set up with the o2 sensors, laz
ratman is offline
Old 08-22-2005 | 05:01 PM
Originally Posted by sutphen30
is this a separate system or an up grade to the dyno's sencing channels??sounds like a great setup.
This O2 sensor set up it's been out for a while but just recently has it come down in price for a working person to be able to afford it I've heard of manufacturers using it and the second it was at my reach I jumped at the opportunity to purchase it for development purpose here in the shop the way it works is there is a O2 sensor in each cylinder pipe so the person can fine tune the carb or specifically the efi set ups . You are able to track it through the rpm range and it works separate to the dyno it runs off the comp in it's own program.
Old 08-25-2005 | 01:07 PM
Here is the finished engine at the cabinet shop ready for shipping with all accessories and custom wiring harness installed .
Attached Thumbnails This weeks Mesa Project 670 hp-hpim0712.jpg   This weeks Mesa Project 670 hp-hpim0715.jpg
Old 08-26-2005 | 12:44 PM
Love the pics! How are those rocker arms holding up?
Back4More is offline
Old 08-26-2005 | 01:29 PM
Viper31's Avatar
What back4more said. Are those Jesel Sportsman Series rockers? Also what comp. ratio are you running Laz?
Viper31 is offline
Old 08-27-2005 | 05:03 PM
Strip Poker 388's Avatar
Rob
Laz I see you said your trying different port configurations.
Are you doing this or Dart?
And are you seeing much difference than there standard CNC port configuration???You must be doing a lot of R&D on getting these #'s
Rob
Strip Poker 388 is offline
