496 exhaust heat sensor >
Old 08-20-2005 | 07:12 PM
boatfreak's Avatar
Default 496 exhaust heat sensor
Well I was doing great on this CMI project until one of my heat sensors decided to seize into the old manifold. I doubt I can get one on a Sunday so is there anyway to short around this thing. ie clip the two wires or tie them together
I just want to get it running enough to check things out.
boatfreak is offline
Old 08-20-2005 | 10:56 PM
Dave_N's Avatar
Default Re: 496 exhaust heat sensor
You don't want to short it or leave it disconnected, that would result in Engine Gaurdian mode being activated and Available Power will be reduced to 90%.
You should be able to use a resistor to simulate the sensor. The Merc diagnostic manual lists the sensor resistance at 11.01Kohms at 70 deg F, and 10Kohms at 77 deg F. Thats all the info they give.
I think a 1/2 watt 7.5Kohm resistor would come close to simulating normal operating temps (115 to 135 deg F). You really just want an "in range" resistance that will keep the ECM from seeing a short or open circuit.
Keep in mind that I have not actually tried this, but it should work.
Dave
Dave_N is offline
Old 08-21-2005 | 08:10 AM
Payton's Avatar
Charter Member #927
Looks like a trip to Radio shack is in order. Good luck Mike.
Did you get your pipes together?
Payton is offline
Old 08-21-2005 | 06:47 PM
Payton's Avatar
Charter Member #927
Mike, How did you make out??
Payton is offline
Old 08-21-2005 | 10:25 PM
boatfreak's Avatar
I gave up and baled hay all day. I hope to have some time over the next few days and maybe I will make the water for some testing by the middle of the week. I found one boat dealer open in all of Indy and they told me that there parts dept. was not open on Sunday. I also need to talk to CMI in the morning. If nothing else they sure look sweet.
raeburn
22
03-05-2009 01:11 PM
davis777
5
06-03-2006 10:14 PM
Rage
Nordic
3
11-14-2005 09:36 PM
Rippem
2
06-28-2004 11:57 AM
bouncedcheque
0
05-05-2004 10:00 AM
