MSD IGN Proplems >
MSD IGN Proplems
MSD IGN Proplems
Old 08-21-2005 | 03:27 PM
CigBoat's Avatar
Default MSD IGN Proplems
My port motor was not getting any spark so I switched my staboard motor box over to the port motor. It now fires right up but it is running real rough. The tack is bouncing all over the place and it sounds bad. I was going to try switching over some of the other stuff butt it started raining. Do any of you have any ideas where I should start as to searching for the problem. I was planning on leaving next week to go on a trip and would love to have her running right.
The motors are 468's with Blower Shop 8/71's and all msd (blaster coil, soft touch rev limiter,caps,wires, and dist)
Todd
CigBoat is offline
Old 08-21-2005 | 05:57 PM
Default Re: MSD IGN Proplems
The trigger wires from your distributor(or crank trigger) may be close to a sparkplug wire that is getting bad. The trigger wires should be routed away from the plug wires and coil wire anyway, but if a high voltage wire is leaking, it will cause an erratic spark. You may also want to check the grounds closely. Good luck.
toolz is offline
Old 08-21-2005 | 08:29 PM
mr_velocity's Avatar
Check the coil also, I lost my first Blaster coil last year. Ran like crap, then wouldn't run, then next day run like crap until it finally died for good.
mr_velocity is offline
Old 08-21-2005 | 10:00 PM
50boat's Avatar
when i in staled the new moters , i had a coil go bad within 2 hr. then 4to 6hr, then antherone ,another. this was with all new msd stuf. so then i buoght 4 , just for spairs in the boat after much anger and calls to m.s.d. the last call, got got the fix my coils wer mounted in stock poszion, and was told they would not cool thier self. know thier mounted up right , 30hr. later no coil failer
50boat is offline
Old 08-21-2005 | 10:01 PM
articfriends's Avatar
look for signs of arcing on the coil,heres what mine looked like,Smitty
articfriends is offline
Old 08-21-2005 | 10:09 PM
CigBoat's Avatar
Thanks for the replies! After doing a little research I know I need a new box so I ordered a coil and a set of wires also. It cant hurt to have the new stuff as a spare if I find something else. For the first time I have something planned to use the boat and this happens so it just figures. Summit had the best prices I could find also!!
CigBoat is offline
Old 08-22-2005 | 06:54 AM
birdog's Avatar
Some good advice on here. Sorry I couldnt be of more help !
birdog is offline
Old 08-22-2005 | 06:02 PM
blue thunder's Avatar
Make sure the ingintion ground wire is making good contact.
BT
blue thunder is offline
Old 08-22-2005 | 09:42 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
i have had 2 coils go bad in the last week. the plugs would spark when hooked to wirer's but very small spark. when i put new coil in motor never ran better. if using msd dist. & cap be sure no corrision is starting to form in dist. around magnetic pick area. if so bead blast dist & clear coat it helps alot. RON BENDER
WILDTHING TAZ is offline
Old 08-23-2005 | 07:44 AM
mopower's Avatar
Toxic FORMULA
MSD
mopower is offline
