Outboard gurus
I dont really know chit about them other than theyre too quiet.
Im looking for a used/ fairly fresh rebuilt 2.4 Merc or similar.
What do I need to look for when buying used, ive noticed a lot of guys seem to post induvidual cylinder compression in their classified ads......what is good compression for theese motors? Can I use a gaffrig style throttle / shifter setup or does it have to be one of those goofy huge control boxes like you find with most outboards? Anything to worry about in the lowers, or are they considered "not a weak link"??? whats the typical lifespan of a powerhead? Anything else I should look for or ask about?
Try posting on "screamandfly.com" on the tech. section. They have some the industries best engine builders on the site. It's the Offshoreonly of outboards. It's a free site to boot
They have not made 2.4's for at least 10 years. The compression will depend on the powerhead. Go to www.Screamandfly.com and ask this same question.
What kind of boat are you planning on putting it on, the 2.4's + 2.5's are better for a lighter boat and the 3.0's are better for a heavier boat. Scream&Fly is the outboard resource but there are some of us with mixmasters here also.
Caleb
Caleb
The compression will vary depending on the type of motor you are looking at, the higher the compression the better your fuel needs to be. The important thing is that there is minimum differences between cylinders
Yes you can use Gaffrig style throttles and shifters.
This depends on what you are using the motor for and what gearcase it has, if you are looking for a high performance motor you would want a sportmaster or torquemaster gearcase depending on how fast the boat you are installing the motor on will go.
I think that a powerhead that is well maintained and run with clean oil and fuel should get 1200 hours unless run at very high RPM's all the time.
Caleb
going on a 16 ft ocean express cat.
I think the factory weight is right around a thousand pounds, it may be slightly heavier when Im done with it, the transom is rotted so I will be replacing it quite a bit srronger than the origonal.
yes im serious.
I think the factory weight is right around a thousand pounds, it may be slightly heavier when Im done with it, the transom is rotted so I will be replacing it quite a bit srronger than the origonal.yes im serious.
getting hard to find try jaco marine .
