BAnks Turbo Set-up >
BAnks Turbo Set-up
BAnks Turbo Set-up
Old 08-25-2005 | 02:30 PM
CIG3's Avatar
Default BAnks Turbo Set-up
I'm looking at a 28 Cigarette with old Gale Banks twin turbo set-ups with a single carb. Anyone know anything about these things. The engines are 400cu.in. chevys.
To make things better this is all mated to arneson #6 drives.
CIG3 is offline
Old 08-25-2005 | 03:08 PM
Biggus's Avatar
Default Re: BAnks Turbo Set-up
Several years ago, I had a 24' Superboat with the old Gale Banks system. I t worked pretty well although there was a fair amount of turbo lag. A little tough to prop but worked well
The Merc Trans was the weak link. Too much torque.
Biggus is offline
Old 08-25-2005 | 04:13 PM
Scarab28's Avatar
Ran one on a jet boat for many years. No turbo lag but then again it was a jet. Makes big power - most setups were 9-10 lbs boost.
Scarab28 is offline
Old 08-25-2005 | 04:30 PM
CIG3's Avatar
BORG, c-71 trqns in the boat. Trying to get info. frm Banks also.
CIG3 is offline
Old 08-25-2005 | 05:53 PM
Turbojack's Avatar
Got a picture. I have some but will have to dig up & scan. I had a 454 Gales Banks twin Turbo setup for about 19 years. I wish I had the same motor for all the years but I ran 12 lbs of boost & distroyed a few motors. Main problem I had was motor was set up for 100 octane & there were times when it was hard to get.
I would be worried about the exhaust manifolds still being good. I had to cut mine up & repair anumber of times over the years.
Turbojack is offline
Old 08-26-2005 | 10:45 AM
CIG3's Avatar
I don't have any picture but will try to get a few. This is small block chevy and uses stock mercruiser logs to mount the turbos.
CIG3 is offline
Old 08-26-2005 | 01:40 PM
Turbojack's Avatar
OK, don't know anything about the small block. I would just check the motor & make sure it leak downs OK, then run it. If no smoke out the exhaust that means the seals on the turbos are OK.
Old 08-26-2005 | 03:07 PM
Strip Poker 388's Avatar
Rob
I have one of the set ups if anybody want one???
Strip Poker 388 is offline
Old 08-26-2005 | 05:53 PM
Payton's Avatar
Charter Member #927
You can also look in the outlet side of the turbo and make sure there is no fim of oil. If there is the turbo seals are going out. The can be fixed al it takes is $$
I ran a similar setup for 3 years on a 486" Ford.
Does the system have a carb box or are the turbos mounted in front of each turbo?
Payton is offline
Old 08-26-2005 | 06:43 PM
hpy540's Avatar
How much? i have a Buddy that is interested in one
[email protected]
hpy540 is offline
