What could cause this ?? >
Old 08-25-2005 | 06:20 PM
Scarab3DMC's Avatar
Default What could cause this ??
Problem ,, the boats a 83 -34- Scarab III... with 502 motors with 177 blowers fresh TRS drives..... Borg warner trans spinnin 27'' pitch Hydromotive Q-IV's ..the problem is that outta the hole it has no problems... but around 4200 + rpm when the blowers are kickin in .. the starbaord prop spins loose,..engine rpm increases to limit.. the boat lists... if I back off a few 100 rpm the prop hooks back up.... I experanced this with different props too.. I have 27 and 28's ...it used to do it with just the 28'' .... the 27's had no prob...now it happens with both...WTF??? ANY IDEAS ??
Scarab3DMC is offline
Old 08-25-2005 | 06:57 PM
Ted G's Avatar
Default Re: What could cause this ??
Could be a fitting on the hull that is disturbing the water to the prop and causing cavitation. Got any strainers, speedo pickups, etc on that side?
www.cbpba.com
Ted G is offline
Old 08-25-2005 | 07:02 PM
Yeah, I too would look for some kind of problem on or with the hull causing turbulence forward of the outdrives or something on the outdrive gearcases themselves. But your B/W's could be needing clutch pacs. Check the fluid. "If it's brown, Tear it down" --- Jer
jpclear is offline
Old 08-26-2005 | 07:29 AM
Scarab3DMC's Avatar
Nothing changed on the boat... solid hubs on props... and it dose it with the 27'' and 28'' pitch props... Like I said the 27's used to hold fine, now they are not.... too much stern lift with the q-IV's..??? should I try bravo's again???... or I still suspect the trans????
Old 08-26-2005 | 09:27 AM
I'd say trans. Buddy had the exact same symptoms in an older Checkmate with TRS's. I think I remember him saying a shifter cable adjustment fixed it.
Shah Mat is offline
Old 08-26-2005 | 03:22 PM
Scarab3DMC's Avatar
I ran today...topped off fluids.... twice they broke loose twice they did not...WTF.... the casing vents do blow alittle fluid...I've heard that is a sign of a plugged screen...I may nurse them till fall and yank them when I put the boat away...I may call Marc @ Bamm ...see what he says...
Old 08-28-2005 | 08:55 AM
Scarab3DMC's Avatar
I'm gonna check cable adjustment today...
Old 08-28-2005 | 04:52 PM
Hub insert worn and slipping?
Pure Energy is offline
