Homemade Single Drive Bugs >
Old 08-27-2005 | 10:20 PM
Well,
I took the boat out yesterday and got about 50-52 mph, assuming 10-12 slip, but could only get 3500 RPM. It felt like the bow came up more than last time, the whole boat too, alot higher out of the water. That was with a 17 x 17 bronze prop. I thought I would be able to turn alot more rpm going down 5 on the pitch from 15-1/4 x 22. I probably lost some with the 2" larger OD. I think I need more than just a carburated big block for this size boat with only one drive.
The engine is:
9:1 Comp, .060 over on the bore,
small isky roller cam, .570" lift, 240 dur. @ .050, 110 centers
edlebrock performer rpm heads,
Victor Jr. Intake, and an 850 holley.
How many HP would you think? Enough for a 28' boat?
I haven't even gotten the weight or COG yet.
Anyone have any thoughts???
It was very nice getting up on plane at least. If I can just get it to 4800 or 5000 rpm, I would be happy.
Thanks for any help.
Attached Thumbnails Homemade Single Drive Bugs-100_0839.jpg   Homemade Single Drive Bugs-100_0831.jpg
cjsdad62 is offline
Old 08-28-2005 | 08:04 AM
Default Re: Homemade Single Drive Bugs
If you only turned 3500rpm that is not even close to the power band of that cam. Tell us more abour that drive. Did you build it? Any pictures? Seems to me you have plenty of HP.Just need to dail in the prop
mmwalters is offline
Old 10-14-2005 | 09:02 PM
Here's a picture of it. I did build it. Got any ideas on what prop to try?
cjsdad62 is offline
Old 10-14-2005 | 09:05 PM
johnnyboatman's Avatar
looks like it needs more of a cleaver style prop.
johnnyboatman is offline
Old 10-14-2005 | 09:10 PM
That inboard prop Just will not work, Cleaver or chopper style prop will work much better
Hot Boat
15
09-17-2007 07:11 AM
Michael1
3
03-05-2007 10:06 PM
BAJA WILL
11-28-2006 08:36 PM
cjsdad62
10
10-16-2005 07:34 PM
timucin
01-30-2004 07:09 PM
