2000 carb'd 500hp valvesprings >
Old 08-29-2005 | 09:01 AM
BajaRunner's Avatar
Default 2000 carb'd 500hp valvesprings
Does the valve spring issue occur in 2000 model 500hps that are carb'd?
BajaRunner is offline
Old 08-29-2005 | 11:50 AM
baja36ft's Avatar
Default Re: 2000 carb'd 500hp valvesprings
I THINK SO MINE WERE BUILT IN 9/99 NEEDED TO BE DONE!!
baja36ft is offline
Old 08-29-2005 | 02:01 PM
1stfntn's Avatar
Yes, I had some broken inner springs at 158 hrs. 200 HP 500 Carbs. And just an FYI, I ordered the replacement springs Teague recommended in his Powerboat article (can't remember the manufacturer off the top of my head). Got them back in March and the quality was poor. My engine builder noted 30lb differences in the spring pressures after only 10 hours of use. Not sure if others have had similar experiences with poor quality springs, but may want to check. Could have been just a bad set I got, but I would check it out.
1stfntn is offline
Old 08-29-2005 | 02:19 PM
G Man's Avatar
How would I know when to do mine? What symptoms did the engine have?
G Man is offline
Old 08-29-2005 | 02:28 PM
jdnca1's Avatar
Went with Isky 8205plus endurance springs on my 2000 500EFI's @155hrs and yes the originals were sagging, although they probbly would have made it to ~200hrs.
jdnca1 is offline
Old 08-29-2005 | 02:33 PM
BajaRunner's Avatar
I think your supposed to do it before there are any symtoms.
Old 08-29-2005 | 03:01 PM
BajaRunner's Avatar
If they were sagging, did it run better with the new ones? Or they just needed replacement?
Old 08-29-2005 | 05:14 PM
jdnca1's Avatar
I just did it. Did the head gaskets too, which would have never made it through another season on one motor in particular. It did run better, probably because I bumped the rev limiters up at the same time though.
jdnca1 is offline
Old 08-29-2005 | 05:16 PM
jdnca1's Avatar
Mainly the power starts laying down....then if you pull the valve covers you'll usually see a broken spring as the cuplrit. Make sure you look at the inner springs also....
jdnca1 is offline
Old 08-29-2005 | 06:27 PM
1stfntn's Avatar
Nothing noticeable when running the engine (at least on mine). My head gaskets weren't going to make it another season either. Agree that you should check the inner springs, that's where my broken spring was.
1stfntn is offline
BajaRunner
13
02-07-2014 08:32 AM
1stfntn
Prop Talk
6
08-18-2005 08:48 AM
1stfntn
Fountain
2
08-17-2005 10:24 AM
ISurvivedNMU
0
04-08-2004 08:23 AM
pullmytrigger
4
01-30-2002 10:15 PM
