Good Day
Old 09-05-2005 | 08:45 PM
RJBBC's Avatar
Registered User
Default Good Day
I have always wondered how a 259 Convincor would run with a Baja 25 Outlaw. Today I finally had the chance to fulfill that curiosity. While exiting the Marina I noticed an Outlaw zoom by. I decided to pick a race and it was on. I pulled beside the Outlaw at about 55MPH (speedo) and gave a race signal. The driver of the Outlaw gave a positive head nod and off we went. The Checkmate slowly started to pull away. Don't get me wrong the boats were similar in speed, but after a mile or two the Checkmate was a couple of boat lengths in front. After running out of room entering a no wake zone the Baja pulled beside me and asked what I had for power. A 454MAG I replied, and no response. I then asked what he had for power. He responded, "same thing". Well hot damn, I thought, you just made my day.
Go Checkmate,
Rob
RJBBC is offline
Old 09-06-2005 | 06:52 AM
Vinny P's Avatar
I hate the winter!!
Default Re: Good Day
When I had my stock 454 Magnum, I ran a 27 Baja a few times with a 502. The results were the same as yours. I would egde him out a bit everytime.
Vinny P is offline
Old 09-06-2005 | 08:28 PM
RJBBC's Avatar
Registered User
Why are the Checkmates outrunning the Bajas with the same power? Maybe this is to general of a statement, but since I just outran a 25 Outlaw with the same power I am going to run with it. Common sense would tell me it's weight, any thoughts?
RJBBC is offline
Old 09-07-2005 | 01:59 AM
articfriends's Avatar
Could be a million factors,weight,fuel load,propping,anything.My 272 baja stock with a 502 went 65 propped perfect w/virtually no fuel,62 w/full tank and 3 people. I hear that checkmates porpoise at part throttle and bajas usually don't due to hook built into the hull. If thats the case and you had a 25 outlaw and 259 side by side w/same power AND they were identical in weight then the checkmate would outrun it every time IF it had less or no hook in the hull. I had a friend with a sunsation aggressor w/330hp 454 with just a cam and no other mods,his boat was 7 mph faster(68-72mph) than my boat stock with a 502,of course his boat was only 7 feet wide too,Smitty
articfriends is offline
Old 09-07-2005 | 07:42 AM
They've always been running faster than same size Baja's. Your 259 is 4000lbs, the 25OL is 4750lbs. Your 259 has a narrow bottom (approx. 6'-3" wide at transom), the 25OL is almost as wide at the bottom as it is at the hull/deck joint. Your 259 has a far better overall hull design, aggressive strakes, tapered transom, weight shifted more to the rear, natural bow lift, and so on. Not that the 25OL is a bad design, it's actually easier to drive than the 259.
I'm surprized you weren't out in front of that Baja even farther...I'm wondering if he actually had a 502 in it. I own a 259 that runs low 70's (72 GPS) with a 496HO/425hp. I know one guy with a 25OL with same power and runs low 60's, might hit 65. I know another guy with a Baja 272 with 502/415hp that runs mid 60's also.....I can actually squeak by 25' Bajas with HP500's, honestly. Even though I am a Checkmate fan, I truley think the Bajas are a decent boat, there are many of them where I live and I am just as familiar with the Baja models as I am the Checkmates, they are just a little slower.
Ck1flyer is offline
Old 09-09-2005 | 04:46 PM
RJBBC's Avatar
Registered User
Narrow bottom, I never thought about that. The beam on the 259 is 103 inches according to Checkmate but the bottom is narrow due to the tapered hull design. It gives the appearance of a wide body boat from the topside but it actually has a narrow running surface. I am learning more about our boat everyday. Good stuff.
RJBBC is offline
Old 11-18-2005 | 11:59 AM
rainorshine's Avatar
RJBBC, maybe it was driver skill?
rainorshine is offline
Old 11-18-2005 | 01:17 PM
My 25OL with HO does 69 on GPS, if others are getting low 60's they're not driving the boat.
Showdown is offline
Old 11-18-2005 | 01:27 PM
I doubt that. Not on GPS and Not with 425hp / 496HO..... If you are being honest, that is an exception. I'll give you 65. There are tons of 25 OL's around here, I'm around them all the time. Never seen one push 70 with stock power. With HP500's they run low 70's....
Ck1flyer is offline
Old 11-19-2005 | 06:06 AM
RJBBC's Avatar
Registered User
I doubt that, although I have logged 180 hours behind the wheel so I am getting comfortable with the WOT trim.
RJBBC is offline
