Transom Assm Torque Specs >
Old 09-06-2005 | 07:37 AM
pachangalpina's Avatar
Default Transom Assm Torque Specs
I am replacing my '88 Bravo transom assm's with new ones but found no torque specs with them. My old ones had some alum stove bolts at the bottom and some bolts at other spots and studs at the top and my manual say to torque to 20-25ft/lb. The new ones have 8 studs but I need to know if it is still the same torque spec.
I also found that they have changed the exhaust block-off plates and I had to machine a notch into my old ones to get them to bolt up.
pachangalpina is offline
Old 09-06-2005 | 07:58 AM
Default Re: Transom Assm Torque Specs
I dont know the specks but I know when I did mine I had gone over them about 5 times each to get them the all same.
z.zuperboat is offline
Old 09-06-2005 | 12:23 PM
GOODT's Avatar
below are the torque specs
File Type: doc
GOODT is offline
Old 09-06-2005 | 01:29 PM
THANKS
Old 09-06-2005 | 09:56 PM
hillbilly24's Avatar
Make sure you don't overtorque it at all, they like to crack especially if the transom is dead even across the surface. I've found it's on of those places that you really want to use a good torque wrench.
hillbilly24 is offline
Quiet Storm
10
04-06-2006 10:22 PM
KCHOTBOAT
4
08-02-2005 06:21 AM
Dono
6
07-30-2005 01:15 AM
KCHOTBOAT
3
04-25-2004 04:22 AM
RCM255
3
07-12-2002 10:31 AM
