Got my 380 up to 90mph yesterday!
I got mine up to 70........degrees, I pulled it in my warehouse to do some work. I found the up trim switches don't work for the drives, must be a wiring problem. Also noticed that with the whipple on the starboard engine I might not be able to remove the battery without removing a trim pump
. I also looked at the feasability of putting in valves on the sea strainers. Looks like it would be easier to pull an engine instead of all the upside down ass busting it would take otherwise. This I will most likely wait on.
Scott: I assume you were getting your wind faring finished up. You gonna post some pictures?
Ray
[ 01-19-2002: Message edited by: Raypanic ]
. I also looked at the feasability of putting in valves on the sea strainers. Looks like it would be easier to pull an engine instead of all the upside down ass busting it would take otherwise. This I will most likely wait on.Scott: I assume you were getting your wind faring finished up. You gonna post some pictures?
Ray
Ray
Ray
Ray,
No it was some touch up work on the bottom and a few items that were left open from last year.
I still don't own a good digital camera I need to buy one so I can take a few shots. The ones I had posted are a couple years old. I will be pulling both my motors and doing a few upgrades soon. (offshore mounts and head work). I will also install a GPS speedo,Optima batterys,boxes and spare prop holders.
[ 01-19-2002: Message edited by: Scott ]
I have Steps & Bubbles!
