Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Matching paint on fountain >
Old 09-08-2005 | 02:16 PM
sleeper_dave's Avatar
Question Matching paint on fountain
I have a '91 Fountain 27 Fever. I have a few little spider cracks and scratches on the transom, and some wear spots on the hull from the forklift (boat was previously rack stored).
I want to find some gel coat that i can just brush on in some of the cracked/worn areas, primarily to prevent water intrusion, but also for cosemetic reasons. Some touchup paint if you will.
Where can i find some touchup gel coat to match my boat?
sleeper_dave is offline
Old 09-11-2005 | 11:42 PM
Default Re: Matching paint on fountain
dave, I'm no gel guy like some of the others here, but you wouldn't get a perfect match of gel from the factory if you had to. The reason is each batch is "close" to a standard color formulation that all batches are mixed by. However, side-by-side comparisons of any 2 batches will be different to some degree. Saying that, any white gel (can be tinted to match) would be better than nothing to keep the water out of the glass. You're smart to address this issue early to protect your investment. Anyone who does fiberglass work should have gel that they will sell you. G$
Gmoney52 is offline
Old 09-12-2005 | 08:18 AM
Thanks. I know it won't look perfect if i'm just brushing it on anyway, so "close" is good enough. There are a few fiberglass shops around that i can try.
poolshrk
08-17-2006 04:33 PM
Retriever
1
05-31-2006 11:06 PM
splashandburn
5
05-30-2006 08:28 PM
splashandburn
4
03-07-2004 09:42 PM
32fever
Fountain
4
05-10-2002 11:57 PM
