on engine still overheats at wfo..any ideas
one engine still gets hot wheni pin the sticks. it will run at 4k rpm ok but it is always 20* hotter thean the other eng. when i go wfo the temp steadily climbs till i back of to 3000 or so then it comes back down. i have huge offshore water pic up all new hoses, put new w/pump impeller and hsg on last week. all my coolers are new ecept the p/s cooler which happens to be on the eng that gets hot bit i ran a piece of heavy wire thru every tube in it and there are no blockages. i was thinking perhaps i hav a restriction in my exhaust but water is flowing out both pipes. any suggestions on what i might try next. thx in advvance, ratman
Bravo drive? Check the hose from the drive outside the boat all the way in. Have seen them go bad inside and restrict flow just enough to cause overheat at wot. What a b*%#h to find!! --- Jer
Had same problem 2 seasons ago. I replaced sea pump impellar, checked all hoses, checked the inlet tube at the drive, replaced thermostat...everything.......
I finally removed the thermostat completely and that cured the problem.
I replaced thermostat with a high-flow unit that I bought from Summit Racing. Been working great ever since.
Removing The Tstat Isnt A Real Good Idea,W,ith It Out The Water Will Move To Quickley Threw The Block And Not Absorb Any Of The Heat,The Temp Guage Will Show Cooler Because The Water Is Always Going To Be Cold As It Now Moves Very Fast,The Tstat Is Designed To Slow The Water Inorder For The Water To Remove The Heat!Same Deal In Your Car,Hre It All The Time!You Really Need To Find The Problem And Fix It!Merc Or Who Ever Does Not Install Parts That You Dont Really Need!! Good Luck!
