25 Outlaw Owners. What size and brand props >
Old 09-10-2005 | 09:19 PM
G Man's Avatar
Default 25 Outlaw Owners. What size and brand props
OK guys, what brand and size props are you using out there and with what engines?
G Man is offline
Old 09-10-2005 | 10:56 PM
TURBOED's Avatar
Default Re: 25 Outlaw Owners. What size and brand props
the topic is old,i say try a search first.
TURBOED is offline
Old 09-11-2005 | 12:57 AM
Blewbyyou's Avatar
I do believe there is another post a long time ago, but I am running a 23 pitch mirage converted to an acelerator and polished by Houston prop. I have the 496 HO (425hp) and I get 68.1 GPS (best). Hope that helps.
What do you have?
Blewbyyou is offline
Old 09-11-2005 | 12:59 AM
Blewbyyou's Avatar
Thumbs up Re: 25 Outlaw Owners. What size and brand props
By the way... I would highly recomend Houston prop. (here on OSO) They took my prop back 2 to 3 times until we got what we wanted out of it. Darren is great to work with. Just my $.02
Old 09-11-2005 | 07:48 AM
liquid asset's Avatar
Ask away, 454 mag 23" mirage, 502 mag 23" mirage plus, 500hp 25" mirage, 500 hp with ext. box 26" bravo
Mine was a 99 502 mag with cmi's K&N and ecu, it ran 68.7 gps at 5,100 on its best day
liquid asset is offline
Old 09-11-2005 | 08:22 AM
G Man's Avatar
Thanks guys!!!!
G Man is offline
Old 09-11-2005 | 07:53 PM
G Man's Avatar
Had 70mph at 5000 RPM with a labbed 24 Pitch Mercury Racing 4 blade. Had the drive all the way in and dragging a bit of port tab. Had a lot of throttle left and as I said plenty of trim to trim out. New boat and got afraid of the RPM's being at 5000. Understand now the motor range is 4600 to 5200 and the rev limiter will kick in at 5350 RPM. Water was about an 18" chop and boat has hydraulic steering. Boat was so stable and solid.
I'm thinking I may need some more work to this prop as far as increasing the pitch a bit.
LIQUID WHAT DO YOU THINK????????????
G Man is offline
Old 09-11-2005 | 08:35 PM
What engine are you running, Must be more than 496 or 502
rdp145 is offline
Old 09-11-2005 | 08:38 PM
G Man's Avatar
HP500
G Man is offline
Old 09-11-2005 | 08:48 PM
HP500
If your running neg. trim and a lot of throttle left then you are going to need more pitch, 5200 is where you need to be running. I guess it all depends on what a lot of throttle means, you've never opened it up to see if it hits the limiter? Its going to be trial and error if you don't know what your peak rpm is.
rdp145 is offline
