New Props NEEDED!
Im Looking For A Set Of New Props!currently Im Running Mirage 3 Blade 25 On My 1998 38 Scarab Powered By 525sc's,I Do Have Smaller Pulleys And Am Running Superchillers And 1.5 Gear Ratio!mid 70s At Wide Open Throttle!whats The Next Pitch I Should Try And How Many Blades?Would A 25 Four Blade Be Better For More Top Or Maybe 26/27??My Set Up Should Get Me 80 With The Right Prop But What Would That Right Prop Be?
I was hitting 5800 with a set of 25 P Mirages. Switched to 26 four blade Bravo1's and turned 55-5600. That's all I've got for ya....but should get you started. Call Throttle Up, they will help you out!!
What gears do you have?
With 1.36 you have 15% slip and with 1.5 you would have 6% which is unlikely. With the 525's you need to run at 5380 at WOT. So you need to drop down in pitch or perform some prop adjustments, such as labbing , pitch change and cup adjustment to increase your RPM.
Julie
Julie
I Have 1.5 Gears,when Starting Off To Get On Plain,the Props Brake Loose Fairly Easily And I Have To Back Off The Throttles,cruise Is Good But It Does Take Some Time To Get Max Speed And When Trimmed I Do Have Quite A Roost!my Props Now Are 25mirage Plus 3 Blade,just Seems Like I Need More Bit!now With My New Set Up(pulleys And Chillers)im Wondering What Will Happen!
Justin
I can only give advice based on experience. I have a '91 Top Gun with Hawk 525's. Came with labbed 27 Mirage plus 3 blades. I had the same problem coming on plane. I switched to a 26 pitch 4 blade as I need more bite for flying ocean swells. I need to lab mine as I can only spin 5100 RPM. If you would like to try the the labbed 27's, let me know.
Hugh
Hugh
HUGH,THAT MIGHT BE A GOOD IDEA,I AM VERY CLOSE TO YOU,I ACCUALY KEEP MY BOAT IN COSTA MESA!E MAIL ME AN ILL GIVE YOU A CALL [email protected]
JJones,
I am re-reading this thread and I am not seeing your WOT RPM...Maybe I calculated your slip wrong. What is your WOT RPM? I think I got it off of the thread you deleted.
I am afraid to say that 6% is to good to be true with 3B props but if indeed this is true I WOULD NOT TOUCH those props...golden. So that being said I would verify all of your data. I would also encourage you to try some 4B props. They will carry your boat much better than the 3B props.
Julie
Julie
Juile,my Wot Is About 5000 At 72mph On Flat Water!this Is Before My New Setup,i Havnt Run The New Setup Yet But With Smaller Pulleys And Chillers A Good Guess Would Be 75/76 At Maybe 5100/5200 Rpm!im Going To Lake Havasu For A Full Week And I Realy Want To Play With The Props,need A Good Direction Though! Thanks For Answering
