Bonding Deck/Hull??
Just curious to how you are bonding the top deck and hull sides. Since my deck is very heavy i was planning to through bolt with stainless bolts then run some fiberglass tape on the inside.
Also anyone have a suggestion on rubrail?
This is for my 1979 Formula 255 project, just getting started.
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
The bolts are going to make it a little tricky when it comes to fiberglassing, even if you are shortening them as much as possible. What if you just used the tape and then bolts for the rubrail that would sort of serve a 'dual' purpose?
Any initial pics to offer? I really dig projects!
Brian
This is a major project, I am just starting to fill the portholes. I will fill the forward deck hatch, and considering filling the second deck hatch. I will not have any cuddy interior, just use it for storage. I have a cabin cruiser for spending the night. After the outside is finished and in primer I will start taking up the floor and transom. Lots of work to do.
I did mine with 5200 and through bolted it. Worked very well. There are other things that you can use but that to me was the easiest. What I liked about it was that it stays flexable just a little. You can get rub rails that are an exact match to your old ones from Taco. Boat US and West Marine can order them for you.
Jon
Jon
Put your best foot forward!
Z06
Detailing, Painting, & Fiberglass
7
06-14-2008 09:01 PM
waterboy222
3
06-13-2007 09:31 PM
