LED's
Old 09-22-2005 | 04:16 PM
dykstra's Avatar
Default LED's
I just purchased LED taillights for my trailer, my question is....Do I splice right into the old wires from the conventional bulb lights after I remove them?
dykstra is offline
Old 09-22-2005 | 07:06 PM
bobonthis's Avatar
Default Re: LED's
Usually the plug on the back is the same if you buy the right ones. But yes you can splice into them, they are still 12volt.
bobonthis is offline
Old 09-22-2005 | 11:30 PM
Default Re: LED's
The flasher is not effected with the trailer lights. Yes, you can splice it in.
Pure Energy is offline
Old 09-23-2005 | 08:47 AM
Wally's Avatar
Were doomed!
Default Re: LED's
i would solder and heat shrink the connection so you dont have problems later!
-Wally
Wally is offline
Old 09-23-2005 | 03:08 PM
Default Re: LED's
I agree, I have a bunch of LEDs to install on my trailer and it is the list of projects. I am going to run new wire (tinned) and solder/heat shink everything). Wiring cause more light issues than then the lights themselves.
happy hours is offline
Old 09-24-2005 | 10:20 AM
dykstra's Avatar
Default Re: LED's
[QUOTE=Wally]i would solder and heat shrink the connection so you dont have problems later! [/QUOT
Agreed, will do, thanks for all the input!
dykstra is offline
Old 09-24-2005 | 11:01 PM
H20 Toie's Avatar
Default Re: LED's
i just replaced all of mine with led's but i went and got ones with the same connectors and just plugged them in.
H20 Toie is offline
Old 09-27-2005 | 02:31 PM
Wobble's Avatar
SORE MEMBER
Default Re: LED's
Just remember that polarity is important with leds, if they are not the plug in kind you should make sure they are working before making permenant connection.
Wobble is offline
allenk4
10
08-15-2007 04:55 PM
TomFTM
09-20-2005 02:20 PM
