Is changing the 500hp valve springs a do it yourself thing? >
Old 09-26-2005 | 09:28 AM
BajaRunner's Avatar
Default Is changing the 500hp valve springs a do it yourself thing?
Im mechanically inclined, and have changed valve springs on cars, but not a 500hp. is it just a basic, pull the old one, put the new one on and set the rockers, or is it something i should leave for a professional?
BajaRunner is offline
Old 09-26-2005 | 10:46 AM
BajaRunner's Avatar
Default Re: Is changing the 500hp valve springs a do it yourself thing?
did you have to pull the exhaust?
Old 09-26-2005 | 11:09 AM
vandeano's Avatar
I had to remove mine do to the fact I could'nt get no leverage. I guess it would all depend on what type of tool you use. I had customize my tool. Kept bending.
vandeano is offline
Old 09-26-2005 | 11:39 AM
BajaIceBreaker's Avatar
Typically you have to remove the exhaust just to get to the valve covers.
BajaIceBreaker is offline
Old 09-26-2005 | 02:20 PM
Can be done without removing the exhaust. Need two types of spring compressors. One being the flat bar style which is good for most of the springs and a screw down style for the ones that are nearest the manifolds and risers.
Did my twins that way so I know it will work. Been there done that.
No problems since. Really no problem before that was noticeable, but did find about 7 (if memory serves me correct) springs broken between the 2 engines. All were the inner springs & was lucky enough that no other damage done and all broken parts were contained within the spring.
Good Luck
Mark
GETTINBYE is offline
Old 09-26-2005 | 02:41 PM
BajaRunner's Avatar
whats the correct way to set the rockers once your done?
BajaRunner's Avatar
and how long should this take me in a twin 500hp 36 outlaw?
Old 09-26-2005 | 03:53 PM
BajaRunner,
If you have all the tools and parts on hand figure on an engine a day. My change was on a 36 Outlaw as well. Took me about 3 days for the first engine as the boat was 100 miles from home to start with. Did not have all the things that I actually needed and one of those days was more or less a total waste of time. Second engine once I had everything I needed was completed in one day and encluded the first test run on the hose before re launching it some time later.
Old 09-26-2005 | 03:59 PM
BajaRunner's Avatar
Originally Posted by GETTINBYE
BajaRunner,
Did you have to pull the exhaust?
Old 09-26-2005 | 04:14 PM
No you do not. Mine are naturally the Gils and have the tall later model risers which as I see it be more of an obsticle than the shorter version.
Just use a 1/4 inch drive socket on a long extension to reach the eshaust side valve cover retaining nuts being VERY careful to not drop then as they are removed and reinstalled.
You will need a flat bar stlye compressor that will work for most of the springs and a screw type compressor for the springs that can not be done with the flat bar one. One of the wasted days came when the el cheapo bar type I had bent beyond being usefull. Morel of the story is spend more and get a quality tool to start with.
Need to also remove the shifter cable assembly and the carb linkage to get them out of the way.
Mark
