02 f 250 7.3 long bed crew cab,  power loss >
Old 10-01-2005 | 12:47 PM
Jonas's Avatar
Default 02 f 250 7.3 long bed crew cab, power loss
anyone ever had this issue.
check eng light comes on when under load like towing boat or going to lake tahoe runnin relativly hard,
someone told me the turbos have notorious problem throwing blades, anyone heard of that??
did it stock now has gibson exhaust chip intake etc still does,
21k miles on it now,.
thanks
Jonas is offline
Old 10-03-2005 | 07:31 AM
MattBMiller's Avatar
Default Re: 02 f 250 7.3 long bed crew cab, power loss
More than likely just throwing an overboost code. Does the light go off after a couple minutes?
Matt
MattBMiller is offline
Old 10-03-2005 | 08:43 AM
Tim G.'s Avatar
Performance Boat Center
Start with the basics....
CHANGE YOUR FUEL FILTER..
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 10-03-2005 | 11:09 AM
Jonas's Avatar
thank U,
will check that.
Jonas
Jonas is offline
Old 10-04-2005 | 11:46 AM
R Addiction's Avatar
AT Cult Member #3
Power loss=Ford.......Nuff said!!
I'm a GM man Tried and true
R Addiction is offline
Old 10-04-2005 | 07:09 PM
Outdrive1's Avatar
Masher touches my
Ouch!!!!
Outdrive1 is offline
Old 10-04-2005 | 08:20 PM
AT Cult Member #3
Just funnin'!! To each his own!!
Old 10-10-2005 | 09:39 PM
vette131's Avatar
many poorly engineered chips cause overboost codes. are you sure the light came on before the chip??? it's very hard to do stock.
vette131 is offline
Old 10-11-2005 | 03:33 PM
BUIZILLA's Avatar
instigator
the light will turn on when the ECM see's 24.5#'s of manifold pressure, or 49 inches/exhaust back prsssure
easiest way to fool this, is to remove the little hose elbow from the wastegate actuator, insert a small ball bearing in the hose end, reinstall the hose on the actuator with a ty-wrap... and viola, another free 7#'s of boost just appeared....
anonymous
BUIZILLA is offline
ratman
4
09-08-2006 06:09 PM
dankerst
27
03-14-2006 08:49 PM
thunderdan
24
03-23-2005 02:54 PM
mopower
02-06-2003 08:07 PM
SUPERSTITIOUS
10-05-2002 01:17 PM
