What is your cruising rpm & speed >
Old 10-02-2005 | 06:34 AM
Craney's Avatar
Default What is your cruising rpm & speed
How many rpms are you turning when you are cruising & what is your speed ????
Craney is offline
Old 10-02-2005 | 07:21 AM
Dave M's Avatar
Veteran: Navy
Default Re: What is your cruising rpm & speed
3400 RPMS = 55 MPH
3800 RPMS = 60 MPH
I seem to get A LOT of prop slip between 2800-3200 rpms so I avoid that range. Above 3200 I'm estimating 8-10% slip.
Dave M is offline
Old 10-02-2005 | 06:50 PM
About 3300 RPM is 32-35 mph depending on trim ballast for me, not typical boat for OSO, a 20 ft bowrider setup for wakeboarding.
happy hours is offline
Old 10-02-2005 | 07:12 PM
GLH's Avatar
GLH
4000-64mph on this
GLH is offline
Old 10-02-2005 | 07:42 PM
34'' bravo 1 lab 3000rpm = 43.6, 3500 = 55.4 mph
32 5p-x hydromotive Same as above a little smoother same top speed
30 Maximas 5 blade 3000rpm = 45.0, 3500 = 57.3 mph non labbed, 3 mph slower top end, excellent out of the hole.
31 Hering 5 blade 3000rpm 49.9mph, 3500 = 60.1mph a little slow on plane, +3 mph faster top end than all above. i like this prop.
03 Donzi zr 38 comp this ride is awesome.
customryder is offline
Old 10-02-2005 | 07:44 PM
R Addiction's Avatar
AT Cult Member #3
3600/54mph
R Addiction is offline
Old 10-02-2005 | 08:22 PM
gsmith9898's Avatar
3200 rpm=50 mph
gsmith9898 is offline
21eagle
3
11-01-2007 09:20 AM
ntox
8
08-28-2006 01:33 AM
bezdikjack
10
08-03-2005 05:37 PM
Dago Racing
Fountain
5
07-07-2005 07:39 PM
X-Rated30
09-24-2003 05:38 PM
