Bravo 4 blade on 3" IMCO Shorties??
It's my understanding that the newer bravo 1 props were designed to get boats with high X's up on plane. Bu if it does't work then you might need to go to a 5 blade.
iam,
The 3" shortie only fits on the Xtreme Advantage SC upper due to prop clearance, thats what the catalog says.. and I do believe the Bravo one prop will fit, but not 100% certain..
That is correct.. the -3" will only fit on the SC upper... thats what the catalog says. I have not seen one in person, so I cant tell you for sure that a Bravo prop will fit. But the shortest lower for an XR upper is the -2"... sorry.
Official OSO boat whore
I believe they are only cutting 2" from the lower. The cavitation plate is cut off so the prop can swing through it.
38Lightning
Drives and Lower Units
1
01-07-2008 05:17 AM
SCRAPMAN1
02-23-2006 10:12 PM
SCRAPMAN1
General Racing Discussion
3
02-23-2006 10:09 PM
