Sea Pumps
Old 10-02-2005 | 06:53 PM
G Man's Avatar
Default Sea Pumps
Have been reading about these as mine just started to leak after almost 5 years. Impeller was fine when I took it apart. motor is a 92 - 502 CI Mercruiser. Have read about guys replacing these every season. Seems excessive. What are other boaters experiencing as far as life of sea pump.
G Man is offline
Old 10-02-2005 | 09:10 PM
Outdrive1's Avatar
Masher touches my
Default Re: Sea Pumps
I change mine every season so that way I don't have to worry about one failing on a weekend when I would rather be boating than wrenching on my boat in a parking lot somewhere. Impellers are cheap insurance. I do the housing every other time I do the impeller.
Outdrive1 is offline
Old 10-02-2005 | 09:19 PM
G Man,
I though mine was fine but changed the impeller anyway last year, ran some sand thru it on Erie this year , just opened it and found one fin missing and the inner o ring melted into the plastic housing. I will be checking it more often ! Good Luck
Indian Summer
Indian Summer is offline
Old 10-03-2005 | 06:05 AM
East Coast B's Avatar
I think conditions and amount of use have a lot to do with it. Fresh water vs salt vs sand... etc.... amount of run time.... I'm in fresh water and put 40 hrs on a year... I go several seasons per impeller..... they're cheap enough to do and give piece of mind....
East Coast B is offline
Old 10-03-2005 | 09:36 AM
customtouch's Avatar
for what it is worth, I was told the general rule was every 100 hrs or two years. which ever comes first
customtouch is offline
Old 10-07-2005 | 11:06 PM
G Man's Avatar
That's good info. Thanks
G Man is offline
Nordicflame
4
07-23-2008 03:37 PM
tomcat
16
06-12-2007 04:36 PM
chuckgo6
4
09-12-2005 10:40 AM
dyno
3
06-06-2005 11:50 AM
Shah Mat
2
07-04-2004 12:24 AM
