No compression in #6 cylinder??? >
Old 10-03-2005 | 04:16 PM
East Coast B's Avatar
Question No compression in #6 cylinder???
My buddy has been having trouble with a popping sound coming from his 5.7 merc. Did a compression test today and the #6 cylinder had no reading of compression. Motor seems to run fine with exception of a popping sound from time to time and top end is off a few hundred rpm.
What should we be looking at as the cause of this problem??? What should we dig into first??
Thanks for your help!!!
East Coast B is offline
Old 10-03-2005 | 04:20 PM
Default Re: No compression in #6 cylinder???
Intake valve not opening, possibly caused by a flat cam lobe or??????
Or a BIG hole in the #6 piston.
Griff is offline
Old 10-03-2005 | 05:54 PM
FOUNTAINATLAST's Avatar
Time to pull the head off and do some inspecting, also could be possible to have bad intake valve...
FOUNTAINATLAST is offline
Old 10-03-2005 | 06:20 PM
hillbilly24's Avatar
I'd check the valvetrain forst starting with the pushrod and rocker assembaly for that cylinder, sounds like a bent pushrod but they are often cuased by something else like a bent or frozen valve or a broken lifter. If you do find a bent pushrod you have to find out why.
hillbilly24 is offline
Old 10-03-2005 | 06:38 PM
GOODT's Avatar
Popping Though Intake Or Exaust???? Could Be Bad Or Burnt Valve, Bad Guild, Bent Stem, Bad Seat, Ect......... Need More Info To Narrow It Down.....
GOODT is offline
Old 10-03-2005 | 06:47 PM
This is what you are looking for...
davids94 is offline
Old 10-03-2005 | 06:53 PM
cuda's Avatar
Stuck valve would be my first guess.
cuda is offline
Old 10-03-2005 | 07:04 PM
GOODT's Avatar
dave that wont give popping just a hell of alot of blow by
GOODT is offline
Old 10-04-2005 | 03:22 AM
cig1988's Avatar
Eliminate the guess work & do a leak down test.
cig1988 is offline
Old 10-04-2005 | 03:35 PM
Thanks everyone!!
We'll start on the top end with the heads/valves and hopefully find the problem there...... at least it's the end of the season if we have to go all the way in!!!!
Good day everyone!!!!
tgersx
10
08-12-2007 12:46 PM
gofastlvr
9
08-22-2006 04:35 PM
375stinger
2
11-23-2005 08:58 AM
BOATING ON A BUDGET
4
02-14-2005 09:31 PM
TEAMBAJA
01-31-2004 03:05 PM
