35x please help >
35x please help
35x please help
Old 10-04-2005 | 05:49 PM
Default 35x please help
After breakin I am standing on my rev limiters at 52000 rpm at 78-79mph. 496ho brovo x drives 32pich 4 blade tabs 2.1 trim 4.2 rev limiters are blinking with 6 people and full fuel. I have more power and wont to use it. Where do I start?
danacnv is offline
Old 10-04-2005 | 08:11 PM
epeek's Avatar
Default Re: 35x please help
I've got the same boat.....and the same problem.
epeek is offline
Old 10-05-2005 | 01:53 PM
throttleup's Avatar
You have 16% with 1.65 gears and 23% with 1.50 gears. Either way your slip is to high. What year is your boat?
Julie
throttleup is offline
Old 10-05-2005 | 08:09 PM
epeek's Avatar
Julie
Mines an 2005. I was wondering if labbing,repitching
the props would help.I dont think 496's
will push 5 blades. Any other suggestions?
epeek is offline
Old 10-05-2005 | 08:51 PM
Mine is a '05. I also tried lab 32pitch props today with no improvement. I don't think any cup was added. My dealer called Fountain to get some direction. I'll keep you updated.
tonybesh is offline
Old 10-05-2005 | 08:58 PM
epeek's Avatar
You would think Fountain knows this. Everyone I've
talked to with a late model X has the same problem.
Maybe the 32 bravo is the best they could come up with.
epeek is offline
Old 10-06-2005 | 08:30 AM
throttleup's Avatar
It is very possible that your drives are mounted to high and this is causing the increased slip numbers. Drive spacers should help your situations.
Julie
Old 10-07-2005 | 08:25 AM
berns29scarab's Avatar
how bout labbed 34's ?
berns29scarab is offline
Old 10-07-2005 | 12:43 PM
epeek's Avatar
I was thinkin the same thing.
epeek is offline
Old 10-07-2005 | 09:46 PM
I have found some 34 pitch props. Going to run the boat light this weekend if the rain stops.
danacnv is offline
