Gear Ratio
Old 10-10-2005 | 06:04 PM
Default Gear Ratio
I have a Ford Expedition with a 5.4L 4x4 that is rated for a 6600 pound trailer with the differential ratio of 3.55 .
I have been thinking on changing my differential ratio for either a 3.73 or a 4.10.
As it is, when my speed is 100 KMH the RPM is about 1450.
What would be the RPM and the max that I could tow with these two differentials ?
Thank you
mars is offline
Old 10-10-2005 | 06:20 PM
hillbilly24's Avatar
Default Re: Gear Ratio
I think the highest tow rating available on an excursion with the 5.4 is 7200 LBS. With the 3.73's you would be runnning 1525 RPM at 100 KMH with the 4.10's you would be running 1675 RPM at 100 KMH.
hillbilly24 is offline
Old 10-10-2005 | 07:50 PM
I thought that was the figure that would come out, but isn't there some other figures to take in consideration when changing a differential ratio.
With a 4.10 ratio is the max trailer weight still the same ?
mars is offline
Old 10-10-2005 | 08:15 PM
according to Ford's spec's the towing cap is 7200 with both the 3.73 and 4.10 geasr I believe.
Old 10-11-2005 | 10:56 AM
The 3.73 gear is only 5% different.
The 4.10 is 15% higher.
Are you looking for better acceleration or just better pulling power.
Try pulling in 3 (drive) not OD.
Wannabe
wannabe is offline
Old 10-11-2005 | 11:22 AM
My first goal is better pulling power, but if I can get both.
mars is offline
PARADOX
01-10-2008 08:02 AM
saulesses
Prop Talk
1
06-13-2007 09:12 PM
saulesses
Prop Talk
0
06-11-2007 11:01 PM
Swede
1
02-27-2004 03:21 PM
EliminatorBill
2
02-05-2003 07:45 PM
