Maximus on F382 w/Bravo 1 Performance >
Old 10-12-2005 | 07:19 PM
sea-crit
Default Maximus on F382 w/Bravo 1 Performance
I'm looking for advice on the issues of drive damage I here about with the new 5 blade props on standard prop-shaft Bravos. I have a '99 382 with 500 EFIs bumped up a bit, (about 520 at the prop) on stand-offs. I am currently running about 76 on GPS with Lab 28 bravos on the limiters at 5500 rpm. I am considering a set of 28 x 15 1/4 Maximus, but fear drive issues. We are primarily easy cruisers, but like to feel the wind now and then.
Any helpful advice would be much appreciated.
Old 10-12-2005 | 07:41 PM
PMTCHIPS's Avatar
Default Re: Maximus on F382 w/Bravo 1 Performance
I don't have any advice on you applicatio, but i have a brand new pair of 5 blade Maximus that have been labbed. They will fit standard and shorty drives and are 15 1/4'" and the blades have been thinned and lots of weight taken off. Make me an offer if you can use them
PMTCHIPS is offline
Old 10-12-2005 | 09:28 PM
blaniac's Avatar
What pitch, I may be interested
blaniac is offline
Old 10-13-2005 | 07:52 AM
throttleup's Avatar
We have been putting 5B props on standard shafts for about 1.5 years now. ONE prop shaft failure has been reported to me...but I cannot substantiate that it was due to the 5B propeller. So all in all it has not triggered the alarms!
Julie
throttleup is offline
Old 10-13-2005 | 09:38 AM
sea-crit
Thx Julie,
I have to put the boat away for the off season but look forward to testing next spring. I'm not expecting anything major on the top end (although 80 would be good), but hope for more efficiency in the mid-range.
Old 10-13-2005 | 09:42 AM
Sydwayz's Avatar
Forum Regulator
Be careful. Docmanrich37 (Active Thunder) has gone through a couple drives since adding 5-blades, and he has XZs. Its not the prop shaft that's going to chit a brick, its the upper and lower gear set.
Sydwayz is offline
Old 10-13-2005 | 11:56 AM
blaniac's Avatar
Are the upper and lower gear sets on the 2005 XR's any better or stronger ??
blaniac is offline
Old 10-13-2005 | 01:28 PM
throttleup's Avatar
That would be a great Colabella quetion question...I will ask him next time we speak.
Julie
Old 10-15-2005 | 07:47 AM
PMTCHIPS's Avatar
Sorry 28" pitch
PMTCHIPS is offline
Old 10-17-2005 | 02:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Maximus on F382 w/Bravo 1 Performance
I needed to call Craig to tell him about some drives I'm sending to him so, I went ahead and asked him about the gear sets. He said there are no changes to the 2005 XR sets. They are the same as the last few years.
On a separate note, the gear sets for the replacements on standard Bravo drives have been upgraded to the XZ sets.
[email protected]
bbladesprops is offline
offshoredrillin
Cigarette
14
06-06-2007 02:11 PM
crb76
Prop Talk
9
11-08-2006 02:36 PM
dbhammer
Prop Talk
19
08-21-2006 05:58 PM
axapowell
Prop Talk
4
04-05-2006 09:29 AM
searafting.no
Prop Talk
7
01-27-2006 09:36 AM
