2wd truck ramp slip fix?
Old 10-14-2005 | 11:49 AM
miamioffshore's Avatar
Default 2wd truck ramp slip fix?
If you have a 2 wheel drive truck that can't get traction on a slippery ramp, has anyone ever tried, snow chains? plywood? carpet strips? Or anything else, that would solve the problem?
miamioffshore is offline
Old 10-14-2005 | 11:51 AM
Default Re: 2wd truck ramp slip fix?
4wd.......
pullmytrigger is offline
Old 10-14-2005 | 12:00 PM
Sean H's Avatar
A to Z
short of 4WD, weight in the back and a good limited-slip rear end are your only hope...
Sean H is offline
Old 10-14-2005 | 12:02 PM
i have a locking rear, just wondering what pulling out a top gun is gonna be like.
Old 10-14-2005 | 01:22 PM
Registered User
Doubt you'd be able to use chains on someone's ramp without someone getting pretty upset. The other stuff you mentioned is worthless.
You might get away with dumping some coarse, abrasive. I've used a blasing media called black beauty- it's crushed coal cinders. If where you're at is heavy with algae, it might bail you out of a jam. An extra 1,000 lbs in the bed won't hurt. If you plan on launching 3 times a week, there's only one way- 4wd
Chris Sunkin is offline
Old 10-14-2005 | 01:43 PM
BajaRunner's Avatar
4wd
BajaRunner is offline
Old 10-14-2005 | 05:16 PM
florida gator's Avatar
Ltd slip
florida gator is offline
Old 10-14-2005 | 06:33 PM
What about brake throttle modulation (this works wonders for humvees) or a front end tow rig to hook up in the front so the rear wheels are higher and on the dry pavement?
Old 10-14-2005 | 07:43 PM
Sean H's Avatar
A to Z
some ramps are so chitty that your hood would be underwater around here....
Sean H is offline
Old 10-14-2005 | 10:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That and the weight of the trailer (tongue) on your front axle would reduce the down force on your rear axle trying to back you out. Your only safe bet is investing in 4WD, or having a buddy there with a tow strap.
Sydwayz is offline
