What  marine pan should i buy or use? >
Old 10-14-2005 | 04:58 PM
Krumbsnatcher's Avatar
Question What marine pan should i buy or use?
I have a gen VI stroker 540 that i am building, the current motor has a 10 qt pan i believe, but i think it was designed for a truck motor.
Anyway, the new configuration for the motor will be an EFI system. I currently have the started collecting the components Ported HP500 intake and Plenum with performance minded injectors, and will be using a FAST computer to control her down the line. I would like to add the best protection since i plan on her being a WOT boat 45% of the time.
Who out there runs marine pans and which ones.
thanks.
Krumbsnatcher is offline
Old 10-14-2005 | 05:50 PM
Default Re: What marine pan should i buy or use?
The Keith Eikert cast aluminium pan is the best wet sump pan you can buy. Pricey but worth it.
JT Klein is offline
Old 10-14-2005 | 06:06 PM
Strip Poker 388's Avatar
Rob
I disagree. Its a good pan but there is better out there.
Maybe One with the kick outs in it .They claim more HP.I never tested and , I bet Chris Straub w/ Steff's has,Maybe he will chime in.
I like the billet fabrications pans the best.I have Keiths on the Hustler , Had the Gil on my Scarab .. Canton ,Moroso and Billet Fab on the cars.
I think the stock gen 5-6 pans are a truck 8 quart???
Rob
Strip Poker 388 is offline
Old 10-14-2005 | 06:52 PM
DanB's Avatar
Charter Member #71
Canton makes a good marine pan with hinged baffles (a must have IMO) at a reasonable price. Its also notched for stroker cranks.
DanB is offline
Old 10-17-2005 | 01:05 PM
Our marine stuff is pricey but the function, fit, and quality of the our pans speaks for itself. Mesa, Keith Eickert, Zul, Sterling, Kurts, Trick all can help you if you need a Stef's pan.
cstraub is offline
Old 10-17-2005 | 03:24 PM
We use Stef's dry sump pans all the time. And all the great stuff from B&B!
JT Klein is offline
Old 10-17-2005 | 03:33 PM
JT Klein,
Thanks for the support.
Chris
Stef's and B&B Performance
cstraub is offline
Old 10-17-2005 | 03:50 PM
mopower's Avatar
Toxic FORMULA
Third season ending soon on my 540s with 10 Qt. Canton pans...no pan problems and oil stays cool
Attached Thumbnails What  marine pan should i buy or use?-dsc01089-small-.jpg
mopower is offline
Old 10-17-2005 | 05:46 PM
Panther's Avatar
Frank's Marine Service
I've got Dooley 10 qts with kick-outs and baffles, they seem to work well.
If I had to do again, i would probably go Stefs
Panther is offline
Old 10-18-2005 | 08:10 AM
The Stef's pans are the best! I know many people who had oil issues before using "marine" pans, and the problems went away after switching to a Stef's pan!
45% at WOT would be very impressive. Looking at the numbers on fast boats that only do Poker Runs, they don't get any where close to that number.
RumRunner is offline
