Info/links/experience converting auto gasoline engines to natural gas/propanane? >
Old 10-15-2005 | 12:07 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Info/links/experience converting auto gasoline engines to natural gas/propanane?
I am considering converting a small 2 seater convertible (4 or 6 banger) to something that would qualify for alternative fuel so I can drive in the carpool lanes (less carpool passenger). (That's a perk here in VA). Anyone have any info to share?
Sydwayz is offline
Old 10-15-2005 | 02:50 AM
hillbilly24's Avatar
Default Re: Info/links/experience converting auto gasoline engines to natural gas/propanane?
Gasoline engines convert to Propans prett well, only a few changes needed mostly in the fuel system. If youw ant he same power that you had before you will have to make some changes though, after the conversion you will hav about 30% less power. most people add a turbo to compensate. CNG conversions are done with diesel engines and as far as I know you can't make a gasoline engine run on the stuff.
hillbilly24 is offline
Old 10-16-2005 | 06:38 AM
offshoredrillin's Avatar
Find a little cheap diesel and start making your own bio diesel and that should qualify, no converting the car and you smell like thrashers french fries when youre driving
offshoredrillin is offline
Old 05-09-2008 | 09:39 AM
dyno's Avatar
Charter Member #655
cng may be the answer for me the sites are all over, try mycngkit.com or cngamerica for starters
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-09-2008 | 10:44 AM
Registered User
You's be alot further ahead dressing up a mannequin.
Chris Sunkin is offline
Old 05-09-2008 | 11:10 AM
I know you can convert gas engine to CNG. As far as diesels go, CNG is like nitrous for a diesel.
Tow-N-One is offline
Old 05-09-2008 | 01:06 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Very old thread, but I still might look into it someday.
Sydwayz is offline
Old 05-09-2008 | 03:26 PM
whats propanane?
Interceptor
4
07-12-2005 11:26 PM
BAJA WILL
01-05-2004 04:16 AM
