Stinger 260
Old 10-16-2005 | 12:28 AM
ENGINESPLUS's Avatar
Default Stinger 260
ANYONE EVER PUT A PAIR OF 383's IN A 260 STINGER .WHAT KIND OF SPEED CAN I EXPECT?
ENGINESPLUS is offline
Old 10-16-2005 | 06:17 AM
Default Re: Stinger 260
Do you mean Mopar 383 mags, or cranked chevy small blocks?
heatbuzz is offline
Old 10-16-2005 | 08:52 AM
Small Block Strokers
Sorry About That
Old 10-25-2005 | 03:07 PM
fund razor's Avatar
Ok... since nobody else will take this one....
All things being equal I would expect 65mph.
fund razor is offline
Old 10-25-2005 | 04:17 PM
These 383's Should Have About 490 To 500 Lbs Of Torque And About 470 Hp.
Old 10-25-2005 | 04:36 PM
glassdave's Avatar
Neno the mind boggler
do you plan on swaping the Alphas to bravos?
08 OPA High Points Champion
glassdave is offline
Old 10-25-2005 | 07:59 PM
Yes I Think That Is A Must
Old 10-26-2005 | 08:58 AM
BOOSTEDSCARAB's Avatar
My trailer manufacture has a 260 w/ 383's pushing around 500 h/p ea and he gets mid 80's so he said. No K-tabs either.
In my opinion 383's are the ONLY way to go if your sticking with v8's for power.
I've decided to go with one Lycoming T53 turbine going thru a custom gearbox to run two TRS's for my 260. 1400 h/p 1/2 the weight. Hmmmmm
BOOSTEDSCARAB is offline
Old 11-04-2005 | 04:53 PM
glassdave's Avatar
yep . . the turbine would be a pretty good way to go. god knows there is enough room. i love the size of the engine compartment in my 260.
mid 80's with no tabs not sure i'd wanna go that fast in mine. i mean its a great boat but the hull is a bit speed limited. mine porpoises like a bee-ahch when i get it trimmed to the moon. best i've seen with my warmed up 350's is 60.9 if i was keeping this boat i would probably toss on a set of Vortech heads and go from there. great boats, cant say enough about mine. yours is going to be awsome with bravos and strokers
Old 11-05-2005 | 06:27 PM
Also Thinking Of Painting Her All Black Maybe With A Thin Lime Green Stripe. Has Any One Ever Seen An All Black Stinger And Is There Any Pictures Around
Feedback Please .
