Hydraulic steering?
Old 01-15-2002 | 08:03 PM
jbrauer's Avatar
Question Hydraulic steering?
I understand that the steering wheel on a full hydraulic system does not stay centered. Is that correct? Can it be centered back up by running it "past the stops" while the motor is running or when the motor is shut down?
jbrauer is offline
Old 01-15-2002 | 08:44 PM
Audiofn's Avatar
Charter Member #232
Post
They keep turning yes. If you go hard to one side and hold it there the wheel on some systems will continure to turn ever so slightly. There is no way to keep this from happening from what I have been told.
Put your best foot forward!
Audiofn is offline
Old 01-15-2002 | 09:04 PM
Vonbongo
Post
You need a 3 spoke Dune Buggy Wheel like Fountain uses, then you never notice that it doesn't center!
(I own a fountain so don't bash me!)
Oh, and I replaced the wheel with a Dino and just live with it.
Old 01-15-2002 | 09:10 PM
Becca's Avatar
Post
Say it with me "L-A-T-H-A-M" ok?
Becca is offline
Old 01-15-2002 | 09:31 PM
BryanTuvell's Avatar
Donzi33ZX
Post
L A T H A M.... Funny, I have the single ram Latham not the full under dash and have never experienced this. Could someone give us the reason why this happens for educational purposes? Is it only on full systems?
Thanks....
[ 01-15-2002: Message edited by: 2001 26ZX ]
BryanTuvell is offline
Old 01-15-2002 | 10:02 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Post
It's only with the full hyd. systems. The add-ons are exempt from it.
One word of caution. NEVER hold the wheel at full lock. Pump will heat up tremendously. Fluid will boil, smoke will pour out from the engine hatch, you will decide between jumping in the water or grabbing the extingisher to put out the 'fire'. And your pumps bushings will be toast! New pump, flush lines.
Been there, did that. Ain't gonna happen again! Thought I was going to loose it to the bottom of the lake.
US1 Fountain is offline
PARADOX
09-06-2007 06:46 PM
26sonic
Sonic
1
05-03-2006 10:09 PM
Whiteknuckle
49
12-07-2005 07:16 PM
Dalump
5
07-02-2005 07:25 AM
CHAOS REIGNS
5
12-11-2002 07:56 PM
