Any 383sbc guys out there?
Thinking of putting 383 sbc together formy 206 rinker.I bought bottom end from friend needing$$$.I'm looking for some ideas for cams,heads,intake,and such.Need to make totally reliable as I often venture off on day trips that could be 100 mile round trip.I was thinking around 300-325hp Boat has 305 with alpha,it runs mid 50s, was looking to hit mid 60s.every now and then.Most running is 25-30 and also use for wakeboading ,ski sometimes.Let me know what you think.
Paul
Paul
There's a few guys with real stout strokers in front of alphas, and some real good threads already on this subject! Do a search on the topic, and your sure to find more info than you can handle!
This response may not be exactly related to boats but I would like to share it with you. I installed a GM Performance Parts 383 crate engine in my 93 Suburban a couple of years ago. It was so impressive that it inspired me to build a 496 stroker motor for my 24 Outlaw that I am also very pleased with. Now I am considering turning my 88ci Harley into stroked 103ci. As we all know.....there is no replacement for displacement. I am sold on stroker setups. Gobs of torque on tap feels great when towing, boating or riding.
I was sent the build sheet with my crate engine. After viewing all of the parts it looks to me like this would make a great boat engine. If interested in it is labeled a HT383. Specs are 340HP 430ft lbs of tourqe.
Re: Any 383sbc guys out there?
Hey I built a 383 for my 77 suburban a few years ago. Some serious power for a 5720 pound vehicle. I'll be be building one for my boat when the 350 gets tired or when I get tired of waiting. I'll be bolting it to an alpha II gen 1. I figure I can buy 3 alpha's for the cost of conversion to bravo 1.
Air Flow Research heads, Performer intake, 750 holley, any good cam in the 220 degree at .50 range, Ross pistons 10.to1 check the comp don't guess, Eagle H beams Clevite H bearings,and a good fuel pump. 380 hp or so.
I have been running a 383.. 540+ hp, naturally aspirated. Runs on 110 octane. AFR heads, 12.7:1 CR, single plane intake, 750 holley, big solid roller,spin it 6000 rpm on a alpha drive...
teaguecustommarine
New Products and Member Discounts
16
11-08-2005 10:44 AM
razor1115
4
03-25-2004 11:13 PM
