72 Nova, 350 or 454?? >
Old 10-19-2005 | 09:14 AM
BajaRunner's Avatar
Default 72 Nova, 350 or 454??
Im redoing a 72 nova. It has a 307 in it right now. Ive got 2 options.
1. 350 4 bolt main, forged crank
2. 454 2 bolt main, cast crank.
I have to change a few things in the car to make it ready for the 454, radiator, springs, etc.
If you had those 2 options, which one would you go with?
BajaRunner is offline
Old 10-19-2005 | 09:18 AM
Default Re: 72 Nova, 350 or 454??
What are you going to do with the car when done?
BGIII is offline
Old 10-19-2005 | 09:20 AM
BajaRunner's Avatar
Its a street car, but i want it fast. I would like to get it in the low 12's high 11's, and Ive heard its not too hard with the 454 with 450-475hp. I just got offered the 350, I realize its an easier changeout, and cheaper to work on, but dont know if ill get the performance i want.
Old 10-19-2005 | 09:21 AM
BajaRunner's Avatar
plus its forged and a 4 bolt.
Old 10-19-2005 | 09:29 AM
Since that particular style Nova was available from the factory w/ a bigblock during certain model years it's not like your trying to shoehorn it in there and cobble parts together, I'd go with the bigblock. Especially since it doesn't look like economy is a factor. I think a car/boat/snowmobile with a larger big torque engine is always more fun to drive than a smaller high horsepower engine, even if they run dead even in a drag race.
The two bolt and cast crank wouldn't bother me a bit.
BGIII is offline
Old 10-19-2005 | 08:38 PM
Big block. I had a buddy a while back that bought a 1970 Skylark convertible. It had a rod knock when he bought it. It was a 350/2 barrel. We discussed what he should do, and I told him to go to junkyard, and get a 455 Buick from a 70's station wagon or electra. I told him to have it redone, with a healthy cam, carb, headers, and some mild headwork. he insisted his 350 would be fast enough if he had it redone and added a 4 barrel and headers. Long story short, he paid 1500 to have the 350 rebuilt, 300 for a 4 barrel holley, 200 for a intake, 200 for headers, and a couple hundred on odds an ends. When it was all over, the performance still sucked. He was expecting a tire scorching musclecar, and he unded up with a slug.
For you, I would say, get a big block, keep the cam and compression conservative, some roller rockers, a good carb, intake, and headers, and you'll have a stout setup that will make you happy. You'll have enough torque to run a 3.23 or 3.42 gears and still have good et's. Im sure you can build and stroke a 350 to a 383, and make some great power, but Im sure it aint cheap and it wont be as user friendly as a big block making the same power. Post some pics
MILD THUNDER is offline
Old 10-19-2005 | 09:52 PM
ever think of a GM crate motor?......they're pretty reasonable and all new
pullmytrigger is offline
Old 10-20-2005 | 07:57 AM
BajaRunner's Avatar
Heres a pic
Old 10-20-2005 | 07:58 AM
BajaRunner's Avatar
No, Ill check on that. I already have the 2 bolt 454, and was looking at something more along the line of 10.5/1
It wont be an everyday driver, just for friday and saturday nights.
Old 10-20-2005 | 01:30 PM
Viper31's Avatar
Other things to consider:
10 bolt rear will not last very long with big block torque
Cooling system upgrade?
Hood clearance depending on what intake manifold you use
Sometimes power brake boosters get in the way with big blocks
Viper31 is offline
