Need brushes for Delco PMGR Starter for '95 454 Merc. >
Old 10-19-2005 | 04:21 PM
Big Block Billy's Avatar
Question Need brushes for Delco PMGR Starter for '95 454 Merc.
Just changed starter in friends boat. The wires attached to the brushes were broken. Am looking for a brush holder kit or just the two loose brushes. Tried searching everywhere. No longer avail from Merc. The starter # is 9000768 any suggestions. I wanted to save the starter as a spare. Thanks, Bill
Big Block Billy is offline
Old 10-21-2005 | 04:57 PM
Default Re: Need brushes for Delco PMGR Starter for '95 454 Merc.
Marine Power Service shows the brush holder Merc part #811863 for $93.30..........Genuine Delco starter 336-1910 exact part #9000768 from local supplier $132.41.........you make the call.
JMS322 is offline
Old 01-27-2008 | 12:39 PM
Post Brushes
found parts from wagner. It is a pg 200 starter, and part # for brush assembly is D41-16 I can't support such thievery as $95 for a brush holder assembly. I can buy the whole starter shipped to me for less, that's not the point though. If I can fix up starters in spare time and make up a bunch of them in an evening in the shop, why pay top dollar and add to an already ridiculously expensive inventory of parts. I do all of this not to just save money, I am rebuilding Carburetors , because I have had too many problems with them, bent rods, worn throttle shafts, etc. same thing with alternators, too many reused/inferior quality parts , Have been doing this for many years with no comebacks. I guarantee all rebuilt ones I install. Ok I got into alternators recently, but I realized that I can build a better unit with all new transpo electronics that are the best and cost a little more than a competetive rebuilder will use. My friend paid $180 for a 12SI Delco alternator with the chrysler mount. It had brand new case , and spark arrestors. It was a whitewashed grave, inside was all reused junk. It lasted a few months. He needed one for his other motor and had to go back three times to get one that worked right. Local shops charge more for rebuilt units than a new one would cost me with my discount. This goes for carbs, Alt's and starters. All with problems. Nothing like paying $165for a rebuilt Mando alternator and having it last a few days and then have to replace it out the labor. Most rebuild shops have less than brilliant people that either don't know or don't care, or have a greedy pushy boss that says"put it together" "get it out the door" .
Plus what's the difference if the customer end's up getting the starter or alternator wet from a bilge full of water etc. I end up having to sell and install another one anyway. I can offer a quality part lets say installed for $200-$300 almost all profit and usually end up with servicable cores. If core is shot, maybe I can salvage a hard part like a nosepiece. I also make sure every boat meets SAE J1171 Specs. Many times have I got a non marine core, but at least it's still good for parts and I know what to do with them . BBB
Griswald
2
10-11-2007 09:50 PM
Rookie
4
08-03-2004 04:00 PM
dyno
9
07-30-2004 05:45 AM
kilroy
0
07-09-2004 12:59 PM
Chris288
06-08-2004 07:37 PM
