Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Best way ro get yellow water stains off transom? >
Old 10-19-2005 | 09:34 PM
G Man's Avatar
Default Best way ro get yellow water stains off transom?
What is the best way and products to get the yellow water stains off the transom?
G Man is offline
Old 10-19-2005 | 09:45 PM
Default Re: Best way ro get yellow water staiff transom?
mary kates hull cleaner
Jaysawesome80 is offline
Old 10-19-2005 | 09:59 PM
Catagory5's Avatar
On-off or superclean. Be carefull they can damage painted surfaces and will remove your wax. FSR,,,Fiberglass Stain Remover works well also. You can also try a cleaner wax or some good old compound. If the stains are deep into the gelcoat you can also wet sand it out and polish it..
Catagory5 is offline
Old 10-19-2005 | 10:44 PM
Ted G's Avatar
Default Re: Best way ro get yellow water stains off transom?
SLX fiberglass and metal cleaner works great. It isn't as harsh as On-Off and doesn't tear up the trailer or paint.
www.cbpba.com
Ted G is offline
Old 10-20-2005 | 05:39 AM
JBravo's Avatar
FSR works the best i found out! U can get it at any West Marine stores.
JBravo is offline
Old 10-20-2005 | 08:40 PM
FX10's Avatar
As long as you don't have bottom paint, go with the On-Off by Mary Kate. Part # MKT 20128 for a gallon, or MKT 2032 for the Qt. It works the best, believe me.
Rick
FX10 is offline
Old 10-20-2005 | 08:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Slimey Grimy
US1 Fountain is offline
Old 10-23-2005 | 10:57 PM
cdscarab's Avatar
Slimey Grimey or FSR, both are safer for painted surfaces.
cdscarab is offline
Old 10-24-2005 | 07:25 AM
Depending on the stain try SnoBol toilet bowl cleaner. It also works great for cleaning your stainless.
Enough 4 Play is offline
tomtbone1993
07-23-2008 03:23 PM
Mackattack
11-05-2007 06:14 AM
cmckay
Baja
3
10-09-2005 01:22 PM
US1 Fountain
30
03-31-2004 06:25 PM
bcoffield
08-05-2003 09:34 AM
