502 Rebuild
Old 10-22-2005 | 07:51 PM
LakeRacer's Avatar
Charter Member #9/ Moderator
Default 502 Rebuild
Ok, my question is simple:
I have to rebuild my engines this winter. I have 1998 502 Mag EFI. I want to rebuild them to HP500 specs or similar.
Who has done it and please list all of the specs for the parts etc. I don't want more than 500hp...I want these engines to be as turn key as possible. I like the fact that I have almost 600 hours on them now and would like to get as many hours on this rebuild as possible.
I'm asking for a listing of parts/specs so that I can go to my engine builder and at least make sure they aren't doing something stupid or wrong.
I know that I could search this forum...but I'm looking for someone who has the "list of parts" complete so that I don't have to mix and match previous answers.
Hey, just call me lazy! But as has been stated before, there is a wealth of knowledge here and I'm picking your brains. Thanks for the help.
Art
LakeRacer is offline
Old 10-23-2005 | 08:59 PM
AIR TIME's Avatar
Default Re: 502 Rebuild
I've had a turn the key 509 since 2000 which makes 647hp .the motor was my 93 390hp 502. then it grew to 585hp in 95 then in 96 change carb had another 10hp, till 2000 then did everything. art
AIR TIME is offline
Old 10-23-2005 | 09:23 PM
hondatv's Avatar
Air Time I'm looking to build a 502 to a 540 and would like to get that kind of power. Can I get some specs ? Thanks
hondatv is offline
Old 11-04-2008 | 06:11 PM
Lakeracer ever find answer to this question, I would like to do the same.
89scarabIII is offline
Old 11-04-2008 | 06:17 PM
SB
HP500 as in the carbed 500hp 502 ?
or
the 500EFI as in the fuel injected 500hp 502 ?
SB is offline
Old 11-04-2008 | 06:31 PM
I presently have 1991 502 mag's with carb's.
Old 11-04-2008 | 06:57 PM
Is this a N/A motor or forced induction? You have supporting documents on the 647HP number?
ROTAX454 is offline
Old 11-04-2008 | 07:11 PM
SB
Merc 500HP Flame Arrestor
Holley 800cfm carb
Dart Single Plane Rect Port (for GM heads) Intake
Crane Cam Grind # HR-284-2S-10IG . You have a Gen IV block so you'll need the retrofit kit - ie: retrofit hyd roller lifters, cam button and etc
Your heads but with 2.25" severe duty intake valves / 1.88 Iconel exhaust valves. Slight bowl work - rumour slight short turn work
I'd bet Crane valvesprings (150 seat / 380 or so open)
crane retainers, locks, pushrods
Crane Gold Roller Rockers
Gill Exhaust - later one's had the taller tisers. Earlier shorter riser one's reverted water.
Hp500 oil cooler/lines set up from Merc
How's that ? Asking me for part #'s would be pushing it. LOL.
A call to Crane will get you all the valvetrain part #'s.
SB is offline
Old 11-05-2008 | 06:42 AM
Thanks less parts then I expected.
32storm
3
10-03-2007 09:21 AM
Pat McPherson
Superboat
67
05-09-2005 02:49 PM
obnoxus
20
02-21-2003 08:20 AM
outlawinil
6
01-21-2003 03:26 PM
obnoxus
6
12-28-2002 11:54 PM
