F-350 Dually w/ 7.3L PSD Poor Fuel Economy >
Old 10-25-2005 | 09:47 PM
p4-33's Avatar
Default F-350 Dually w/ 7.3L PSD Poor Fuel Economy
Hey Gang,
I've got a 2000 350 Dually with a 7.3L, 6-spd manual tranny, 4.10 axles. It has about 80k miles, engine is factory stock.
I've noticed that, even unloaded, my best mileage is 10-11mpg. Towing a 10,000lb load doesn't change mileage much; as long as I keep it under 75mph or so, I get 9mpg. Performance seems to be as good as it's ever been, and I've owned the truck since new. I used to get 15-16mpg unloaded not long ago.
Where do I start looking? Are there any engine codes to look for? Anything else that I can pull from the computer? I've never played with a code monitor, but I have access to one.
Any help would be greatly appreciated, especially with diesel fuel prices at $3.30.
Thanks in advance,
Brian
p4-33 is offline
Old 10-25-2005 | 09:55 PM
traviss's Avatar
Default Re: F-350 Dually w/ 7.3L PSD Poor Fuel Economy
at work I drive a 2000 350 w/ 7.3, 4:10 gears. Loaded with a rack and 3 toolbox's. 90% of the time pulling 12,000+ lbs. Doesn't matter towing or not.. 10-12 mpg thats it. But it does have a diablo sport chip in the computer.. Even with the 12,000 lbs on the back it will still do a burnout
SHHH.. hint hint.... offroad diesal
traviss is offline
Old 10-26-2005 | 05:20 PM
mopower's Avatar
Toxic FORMULA
Hope your boss doesn't read this
mopower is offline
Old 10-26-2005 | 06:52 PM
plumbers crack's Avatar
Thumbs up Re: F-350 Dually w/ 7.3L PSD Poor Fuel Economy
I just bought a 2002 dully7.3 auto and when I picked it up the overhead console read 14.1 I have owned 3 duallys 2003,2004 with 6.0 and 2 7.3 and the milage was always 14.I towed the new boat 11500lbs friday and it went down slowly to 11.2 go figure.Now im running with no trailer and still 11.4?
plumbers crack is offline
Old 10-26-2005 | 07:03 PM
waterheater's Avatar
Question....is there a Ford F350 non dually or other product out there capable of towing a 98 TG, GVW around 14,000 +lbs. (boat,trailer, gas, extra crap, etc.) non 5th wheel diesel?
waterheater is offline
Old 10-26-2005 | 07:09 PM
Outdrive1's Avatar
Masher touches my
For some reason they don't reset after a while, push your reset button after you are done towing to get your mpg while empty again. BTW, mine never reads better than about 9.something. I don't know how you guys are getting 14?????
Outdrive1 is offline
Old 10-27-2005 | 02:50 PM
birdog's Avatar
I use a F-250..{Didnt want the stiffer springs} Air Bags,E Range tires...Good trailer with GOOD Brakes..No problem
birdog is offline
Old 10-27-2005 | 08:53 PM
yes problems...lots of them
Byrdman is offline
Old 10-27-2005 | 08:56 PM
traviss's Avatar
My boss was in the truck with me.. he is a good friend.. He was impressed the ole girl could do it. LOL!
traviss is offline
Old 10-27-2005 | 09:19 PM
PMTCHIPS's Avatar
Originally Posted by p4-33
Hey Gang,
Thanks in advance,
Brian
Check us out at www.pmtdiesel.com
A Superchips Microtuner and Air Intake should help about 3-4 MPG.
PMTCHIPS is offline
