469HO Water Seperating Fuel Filter Replacement >
Old 10-26-2005 | 08:02 AM
Rage's Avatar
Default 469HO Water Seperating Fuel Filter Replacement
Is there a direct replacement water seperating fuel filter for the 496HO (2005) that provides increased capacity for the water and or a drain valve? Specifically I mean a replacement that will screw on to the stock fuel filter mounting on the side of the engine.
Rage is offline
Old 10-26-2005 | 12:27 PM
Dave_N's Avatar
Default Re: 469HO Water Seperating Fuel Filter Replacement
A 2005 496HO should have the Gen 3 cool fuel system, with the cartridge filter, not a screw on.
Dave
Dave_N is offline
Old 10-26-2005 | 12:49 PM
Rage's Avatar
Dave
Dave,
I don't know what to say. I just changed the filter and it is a screw on type and the rig is titled as 2005. When did they change to the Gen 3 cool fuel system?
In any case I have the screw on style, and I would like to get a larger capacity screw on replacement.
Thanks!
Rage is offline
Old 10-27-2005 | 03:37 AM
hillbilly24's Avatar
If you are getting the engine year info based on the boat year that may be the confussion, boat builders often use engines that were built as long as 3 years prior to the boats completion. If the boat is an 05' then the engine could likley be an 04'. As far as the filter, do a search I'm sure hydrocruiser has posted the part numbers from atleast a dozen diffrent companys of replacment filters for that one. That screw on water sep filter is the same one they have used for 20 years.
hillbilly24 is offline
Old 10-27-2005 | 07:51 AM
Rage's Avatar
hillbilly,
That is interesting! I guess the engine serial should tell the real story of vintage.
I thought hydocruiser only tracked oil related items. I'll give him a try.
Rage is offline
SkiDoc
9
02-24-2008 10:33 AM
2Slow4me
0
07-25-2006 11:57 PM
gsmith9898
3
06-26-2006 07:42 PM
BGIII
4
06-07-2006 06:31 AM
Poorsche
2
05-16-2004 11:59 AM
