bottom paint
Old 10-29-2005 | 07:23 AM
Full Force's Avatar
Default bottom paint
Any good way to remove bottom paint,I want to redo the boat this year and want it to look good,the existing is all chipping off,looks like it was sanded before they painted it.
Full Force is offline
Old 10-29-2005 | 01:00 PM
czy40p's Avatar
Default Re: bottom paint
If the paint was put on right the gel coat was roughed up and the bottom paint was put on. I got an estimate from a glass shop to strip it and re-gel coat it for about $2,000 they also recommended applying VC-17 bottoming paint about $1,200, still a bottom paint but better looking and can re-coat when needed. It is on 26' foot hull.
czy40p is offline
Old 10-29-2005 | 01:05 PM
Full Force's Avatar
I would like to leave it off but i keep it in the water,i could scrub it weekely but that would get old,I am going to find a color that looks good on the boat.
Old 10-29-2005 | 07:19 PM
bobpowell's Avatar
245 limited, I'm not sure where you are located. There is a guy here in south eastern Pa. that does dry ice blasting. He mostly does boat bottoms. In a week or so he is going to blast the graphics off my 41 Velocity. I'll post how we make out. BOB POWELL
bobpowell is offline
Old 10-29-2005 | 08:13 PM
I used Petit Vivid bottom paint on my Stinger. Bright white multi-season paint. Looking at the boat you can't tell it's painted. Paint comes in several different colors and they can be blended to exactly match what you want. Great product. Check them out. Picture is of the boat with bottom paint applied.
Attached Thumbnails bottom paint-dcp03077.jpg   bottom paint-dcp02959.jpg   bottom paint-dcp02966.jpg
stinger390 is offline
Old 10-30-2005 | 01:03 AM
Poorsche's Avatar
There was a 60 foot Sunseeker here this summer that had the Vivid white bottom paint on it--you couldn't tell it was painted. The owner complained about stains showing on the white but that would happen without the paint.
Mine has black bottom paint and I talked to Petit about coverage over the black with VIvid--they said whiate and yellow would cover the black without any issues if surface prep was done properly. THey've got great info on website.
The paint guy at the marina suggest I think about the problem the forklift woudl cause with anything but black bottom paint so I put the project on hold till I can get the boat an my own lift but as soon as I can get to that point I'm going with Vivid.
Poorsche is offline
Old 10-31-2005 | 08:26 PM
Full Force's Avatar
I would like to try and match the color of the boat,looks horrible right now,I got the boat in may and put it in for the summer,I will redo it this winter,I am storing it in my works warehouse so I have heat!!
Old 11-12-2005 | 12:31 AM
yesrej's Avatar
i painted my first boat and i couldnt stand looking at it on a trailer. i will not paint this boat. i used it all summer this year and i leave my boat in the water. i pulled it every two and sometimes three weeks to clean the bottom and your right it does get old.the problem is not the bottom of the boat, its the outdrive and the tabs that get the worst of it. this year i will just store it and drop it when i want. but i will spend alot of over nights on it.
yesrej is offline
Old 11-13-2005 | 03:19 PM
I got my bottom paint off with oven cleaner, I srayed it on and let it sit for an hour and then blew it off with a pressure washer. I then painted the bottom with PPG deltron. ( my son did the paint, he didnt trust the old fart). Brian
scarrab30 is offline
Old 11-13-2005 | 03:29 PM
Full Force's Avatar
How did the oven cleaner work? did it get all the paint off?
Magicfloat
01-12-2008 01:07 PM
Nykamp
Detailing, Painting, & Fiberglass
6
04-16-2007 01:55 PM
JLaufer
5
03-14-2005 11:27 AM
CAP071
12
06-08-2003 10:48 PM
The Raven
08-25-2002 11:57 PM
