Fuel pump for above 550hp big block application >
Old 11-03-2005 | 05:53 AM
Question Fuel pump for above 550hp big block application
What fuel pump do most of you run on a engine above 550hp? I've noticed Mercruiser changed fuel pumps on anything above the 525. Do anyone know the fuel pump gpm on the stock Mercruiser fuel pumps, 525 and under and 525 and over?
Karlos is offline
Old 11-03-2005 | 07:23 AM
Default Re: Fuel pump for above 550hp big block application
BG, Carter, and CV products all have a mechanical fuel pump that would supply an engine of that HP. RumRunner on this board works for BG, he is probly at SEMA all this week but you may want to PM and get his advice.
cstraub is offline
Old 11-03-2005 | 07:44 AM
I run a holley black.
z.zuperboat is offline
Old 11-03-2005 | 09:34 AM
mopower's Avatar
Toxic FORMULA
140 GPH Got these on mt 600+ hp 540s....no problems
Attached Thumbnails Fuel pump for above 550hp big block application-dsc01297-medium-.jpg
mopower is offline
Old 11-07-2005 | 10:02 AM
Thanks for the help. Ican use all the info I can get.
Karlos is offline
Old 11-07-2005 | 01:10 PM
Gordo's Avatar
Charter Member #94
MoPower,
Does that pump have the "special" arm that allows you to bolt on to the Mercruiser factory fuel pump/sea pump housing?
I've talked to carter, Holley, and a few others and it seems you can't get a high pressure- big volume pump for Marine application that will bolt on.
PS, I looked at the pic and noticed the part number. I have that actual pump. The arm didn't work on my HP500.
Abby-someone
Gordo is offline
Old 11-07-2005 | 04:31 PM
mopower's Avatar
Toxic FORMULA
Originally Posted by Gordo
MoPower,
That's the number and that's the pump. This Carter will bolt to the block and is internally regulated to 7 lbs. How much pressure do you want?
Since it isn't something you can get quickly I stock a spare so as not to have a totally bad weekend
mopower is offline
Old 11-07-2005 | 04:38 PM
Gordo's Avatar
Charter Member #94
I have one in stock myself, but it won't do me any good on a stock Mercruiser application.
Yes it will bolt directly to the block, but I want to bolt the fuel pump on the factory position in the assembly that drives the seawater pump and fuel pump.
Abby-someone
Gordo is offline
Old 11-07-2005 | 05:48 PM
Panther's Avatar
Frank's Marine Service
What size fittings are on those pumps. Seems all the pumps with the big ports all require a regulator.
Can you get anything that doesn't require a regulator and supply say 700 hp blown??
Panther is offline
Old 11-07-2005 | 06:09 PM
blaniac's Avatar
Aeromotive with a Teague water/fuel seperator
blaniac is offline
