Will putting a hp525 cam in a carb'd 500hp make a big difference? >
Old 11-07-2005 | 10:19 AM
BajaRunner's Avatar
Default Will putting a hp525 cam in a carb'd 500hp make a big difference?
Would putting the hp525 cam in a 500hp give a decent gain?
BajaRunner is offline
Old 11-07-2005 | 10:26 AM
baja36ft's Avatar
Default Re: Will putting a hp525 cam in a carb'd 500hp make a big difference?
If You Bring The Comp Up And Do Some Head Work.
baja36ft is offline
Old 11-07-2005 | 01:14 PM
That should be interesting
Back4More is offline
Old 11-08-2005 | 06:44 AM
Pat McPherson's Avatar
Sounds like a good upgrade to me.
From what I have read here on this forum, the 525EFI cam is a Crane 741 ground on a 114 lsa.
Patrick
Pat McPherson is offline
Old 01-27-2006 | 12:09 PM
with the 114 lsa, is this cam better suited for efi than carb? will the 114 lsa give a flatter torque curve, but lose signal to carb when engine is at an idle?
hpscarab22 is offline
Old 01-27-2006 | 12:56 PM
My guess is that with the 114 lsa the vacuum would be higher at low rpm.
The 454/502Mag cam is the same for carb or EFI and I think 115°lsa.
Patrick
Old 01-27-2006 | 01:35 PM
BajaRunner's Avatar
I went with the crane 731.
Old 01-27-2006 | 02:10 PM
I was just wondering why mercury racing would chose a 114 lsa instead of 112? is it because of overlap or water reversion? I've tried the 731 in a hp500, what it seemed to gain in midrange it lost some at top end.
Old 01-27-2006 | 02:15 PM
BajaRunner's Avatar
I think its more the total package. The 731 is a 112lsa and the stock hp500 is 110lsa. The 525 cam is 114lsa.
Im hoping for some top end gains from the stock hp500 carb to the 731.
Old 01-27-2006 | 04:23 PM
racinfever's Avatar
Great cam great combo ,go for it!
racinfever is offline
