Air Bags
Old 11-08-2005 | 05:10 PM
itilldo's Avatar
Default Air Bags
Need info. Looking to install some air bags and I need recommendations for Manuf and size. These will be put on a 05 Ex 4x4. Load will be 10-12ooo lbs.
Also, should I set these up to be individual's or in tandem?
Truck is stock as of right now but looking to do some work over the winter to help stabilize the overall ride.(info from previous post)
itilldo is offline
Old 11-08-2005 | 05:49 PM
buck183's Avatar
Default Re: Air Bags
Firestone part #2251 if it's 4WD. Part #2255 if it's 2WD.
Firestone or Air Lift either one make nice kits. I've installed both on several occasions without worry.
Buck
buck183 is offline
Old 11-08-2005 | 06:03 PM
Originally Posted by itilldo
Need info. .
Set them up individually, otherwise when you go around a corner it will transfer air from one bag to another...not good. Go with the firestones.
I have them on my dually and would not go it without them......
Bryan
Bryan Rose is offline
Old 11-08-2005 | 06:32 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I am on my second set of Air-Lift 1000s, (second truck with them that is). I love them, and would not want a truck without them. Definately go for individual setup. What is mentioned above is true depending on your load. Folks speak very hightly of the Firestone Ride-Right system as well.
Sydwayz is offline
Old 11-08-2005 | 09:03 PM
BL6
I recently bot a 2004 Ex, (had a 2000 prior). The 04 has 18,000 miles, I have put on new edelbrock shocks, then Firestone ride rite air bags (ex have lighter leaf springs than F250's). And last week installed Landyot Radius Rods, which makes truck track much straighter over bumps etc.
The air bags did lift the rear about 1 3/4" with minimal 5# air.
Have not towed anything heavy yet, does does firm up cornering.
BL6 is offline
Old 11-08-2005 | 09:48 PM
PMTCHIPS's Avatar
Click this link:
http://www.pmtchips.com/_e/Air_Sprin...0_2005Rear.htm
I have these on my perrsonal Exursion. I tow 10K boat and trailer. I get a level ride and proper front end steering control. Great product!!
PMTCHIPS is offline
Old 11-08-2005 | 11:25 PM
RedDog382's Avatar
What is a good price (uninstalled) on the Firestone #2251's?
RedDog382 is offline
Old 11-08-2005 | 11:34 PM
buck183's Avatar
$200 ish give or take. You may be able to find them a little cheaper if you shop.
Buck
buck183 is offline
Old 11-09-2005 | 01:02 AM
Get it with the onboard compressor...push button, pump up and go.
I have the adjustable Rancho's also, set at #5...I run 70psi in the bags...trailers very nicely
Attached Thumbnails Air Bags-trailering.jpg   Air Bags-trk1.jpg   Air Bags-trk2.jpg
Back4More is offline
Old 11-09-2005 | 07:51 AM
Best I coould find on them 3 years ago was @ www.truckspring.com
they carry both brands...
Bryan
