454/420Hp build up
Right now in my excalibur Hawk I have twin 454/420 mercs. Actually, one is a crate 425HP, and the other is a 400 cylone that was supposedly rebuilt to 420 specs. The cylone engine was down on rpm this past season. It ran well, but not that much power.
The engines currently have dual plane aluminum merc intakes, holley 800 double pumpers, mallory breakerless distributors, and 3" log maifolds. My plans are to remove both engines. Regasket and paint the 425 motor. It runs very well.
The cylone engine had good compression on all 8, but I would like to install a new cam(stock crane 425Hp cam), valve springs, and regasket. I also want to get rid of the old crappy manifolds and go to some revolution marine manifolds.
My question is, should I change the intakes? They are the ones that accept a spreadbore or a square bore. Also, I hear there are better cams available. Which ones? I would like a reliable set of 450-475Hp motors. Im thinking between upgrading the intakes, exhaust, and possibly cams, I shouldnt be too far off my goal. It would be great to get another 5mph out of her
The 420 and 400 Cyclone are the same engine with the exception of the carb, intake and exhaust. The Cyclone came with a Quadrajet and probably the dual plane intake you are using now. It also used the 3" exhaust. The 420 came with a Holley 800 and a Wieand X-cellerator intake. It had it's own cast iron individual runner exhaust manifold that was prone to leaks and reversion. Most were replaced with Gil manifolds. The heads, cams and shortblocks are the same.
The 420 was designed for max rpm of 5100. If you put a longer duration cam in it, it'll have to spin faster. I would go to a hyd. roller with more lift and about the same duration. The 420 had very low compression from the factory. Advertised at 8.8 to 1 but probably more like 8.5 to 1 with the deck heights you normally see. Having the heads milled .020 while their off would be a good idea. The Air Gap intake will probably make a few more hp and a good aftermarket exhaust will be good for about 20 hp and take a hundred pounds off each engine.
Will all that get you 5 mph? I'm not sure, that's a big heavy boat. To be sure I would reccomend a 1/4 in. stroker in addition to the above. Your going to have the engines out anyway. Nothing beats cubic inches. Good luck.
You have two engines that are quite different. Your 420/454 is an old Gen IV with a flat tappet cam. Your 425HP crate engine is a Gen VI roller cam engine.
I agree with PYacht, rebuild your Gen IV with a retrofit hydraulic roller cam and the associated parts, link bar lifters, new valve springs...
Your 425HP Gen VI has a rather wimpy cam that can easily be replaced.
Most cam companies have the same grinds for retrofitting Gen IV/V engines as well as replacing the OEM roller cam in your GenVI.
You will want to spin those 454s to at least 5200rpm and probably more like 5600rpm to make 475HP. The "off the shelf" cam that most suggest is the Crane 731.
The RPM Air Gap is a good suggestion for an intake, but many say the Merc/GM dual plane with an additional 1" open spacer is pretty good. If your going to buy new intakes a single plane may work better if your going to prop for higher rpm. Your 800cfm carbs should do the trick.
Good exhaust is a must, those old logs will choke the engines. I would suggest Stainless Marine or similar high flow aluminum exhaust manifolds.
Patrick
Patrick
Be careful how big of an intake you use. In the 5500 rpm and under, Dart, Merlin, Victor will probably lose power to the Airgap. They're better on the 500+ cubic inch engines. The E-xcellerator is a good one for the higher rpm's. It has smaller, longer runner cross section than the manifold above.
According to mercruiserparts.com, they list the same part # for the 400HP, 420Hp and 425HP cam. Weird.
The funny thing is, my starboard engine (425) has powder coated valve covers with the 425 sticker. The intake, which is a dual plane, identical to the 365hp intake, still has the factory merc lock tag on the intake bolt. I guess I really dont know what I have here. I coulnt find the serail number tag on either engine. I know for sure the cyclone engine was rebuilt at one point, because of the timing cover bolts, roller rocker(not Crane golds like the other motor) and it has flat tappets.
So far, I found that the intake part # for the 400Hp is 72608T, and the 420/425 Intakes are 814167. The rockers, cam, are the same. They do however list two diffent fuel pumps for the 420 and 425 depending on serial number. Mine have the block mounted pumps.
Here are some numbers off the engines
Starboard 5716174
Port 6627089
Starboard 5716174
Port 6627089
Either way, rollerizing is a great way to build more power...
Patrick
Patrick
! It's good to see that we all had to start somewhere, lol.
